Home » Newcomers » Newcomers » org.eclipse.equinox.http.jetty cvs help(org.eclipse.equinox.http.jetty error )
org.eclipse.equinox.http.jetty cvs help [message #1501150] Sat, 06 December 2014 14:53 Go to next message
billy sneddon is currently offline billy sneddonFriend
Hi all,
I am trying to follow a tutorial that creates an equinox runtime embedded in a jetty server.
however, when i try to import the project org.eclipse.equinox.http.jetty among others. the error says:
The following errors occurred while importing projects. Some projects may not be loaded.
Could not connect to :pserver:anonymous@dev.eclipse.org:/cvsroot/eclipse: I/O exception occurred: Connection refused: cvs [pserver aborted]: /cvsroot/eclipse: no such repository
i also get the same error when trying to import the team project set found here //www.eclipse.org/equinox/server/http_in_equinox.php
the tutorial i am following is here: eclipsesource.com/blogs/2009/08/15/building-your-equinox-based-appserver-part-1/
any help on this matter is much appreciated
Many thanks
Billy
Re: org.eclipse.equinox.http.jetty cvs help [message #1501233 is a reply to message #1501150] Sat, 06 December 2014 16:31 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
On 12/06/2014 07:53 AM, billy sneddon wrote:
> Hi all,
> among others. the error says: The following errors occurred while
> :pserver:mailto:anonymous@xxxxxxxxe.org:/cvsroot/eclipse: I/O
> repository
> Many thanks
> Billy
This is a web tools question. You'll probably do better to post it in
the Eclipse WTP forum.
Re: org.eclipse.equinox.http.jetty cvs help [message #1502523 is a reply to message #1501233] Sun, 07 December 2014 19:07 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Russel, Jetty is part of the Runtime project, and I believe the bridge belongs to Equinox.
Billy, practically everything except the Orbit and Subversive projects are now in Git, not CVS. You should be able to find the repositories containing the bundles the (outdated) tutorial refers to using http://git.eclipse.org/c/ . The clone URLs are typically listed toward the bottom when viewing the details of a repository. I'd start with (web page) http://git.eclipse.org/c/equinox/rt.equinox.bundles.git/ .
_
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Sun, 07 December 2014 19:11]
Report message to a moderator
Re: org.eclipse.equinox.http.jetty cvs help [message #1502923 is a reply to message #1502523] Mon, 08 December 2014 03:11 Go to previous message
On 12/07/2014 12:07 PM, Nitin Dahyabhai wrote:
> Russel, Jetty is part of the Runtime project.
> Also, practically everything except the Orbit and Subversive projects
(Understood, Nitin, thanks.)
Previous Topic:Re: Eclipse and OpenHAB
Next Topic:using GoogleDrive for Eclipse workspace
Current Time: Tue Apr 16 03:58:29 GMT 2024
Powered by FUDForum. Page generated in 0.06717 seconds
