Re: OCLinEcore Problem [message #1499928 is a reply to message #1499775] |
Fri, 05 December 2014 14:30 |
Ed Willink Messages: 7655 Registered: July 2009 |
Probably, but since you decline to take any notice of
https://wiki.eclipse.org/OCL/ForumNetiquette
that I referred you to previously, you probably won't understand why I
cannot help.
Ed Willink
On 05/12/2014 11:55, Bruno Costa wrote:
> I have added a set of ocl constraints to my metamodel (OCLinEcore) in
> order to generate an editor and export the "Deployable plug-ins and
> fragments". If I run the editor, the OCL constrains works well, but, if
> I generate the plugins, install them in Eclipse and try to validate some
> diagram, an error occurs: "An exception occurred while delegating
> evaluation for the <invariant_name> constraint on <class_name>:
> java.lang.IllegalStateException:nul".
> Do you guys know how can I solve this?
Re: OCLinEcore Problem [message #1500120 is a reply to message #1500097] |
Fri, 05 December 2014 18:02 |
Bruno Costa Messages: 15 Registered: November 2014 |
Hi Edward,
I've read it and understood it completely
It's just that with the information that I provided maybe someone that already faced the same problem could rapidly answer (as many other topics and forums). But OK, I appreciate your tip. I'll let the question open for a while if someone has already faced it. After, when I have more time, I will provide all information requested in OCL/ForumNetiquette.
Thank you for your attention.
[Updated on: Fri, 05 December 2014 18:36] Report message to a moderator
FUDForum. Page generated in 0.03417 seconds
