Home » Language IDEs » Java Development Tools (JDT) » ClassCastException with Java compiler, but not with Eclipse compiler????
Re: ClassCastException with Java compiler, but not with Eclipse compiler???? [message #1500316 is a reply to message #1499633] |
Fri, 05 December 2014 21:54 |
Stephan Herrmann Messages: 1853 Registered: July 2009 |
That's a really weird thing you're trying to achieve.
First: The only compilers generating the code that trows CCE are javac 1.5 and javac 1.6.
Starting with version 1.7, javac agrees with ecj and no exception is raised.
Background: the CCE in javac-1.5-compiled code stems from the head of the loop:
for (Object keyId : list) {
The compiler knows that list contains Long instances (that's how it's declared) hence the javac 1.5 compiler feels obliged to cast the result of Iterator.next() - which at bytecode level has type Object - to the declared Long. Perfectly legal, but unnecessary, because the program is not interested in knowing that keyId is a Long.
Modern compilers optimize the code as to avoid casts that are definitely unnecessary.
If you really want to see the exception (which makes sense as it makes your program fail fast, rather than propagating erroneous values), you could try to change the loop header to:
for (Long keyId : list) {
Now the compilers no longer regard the cast as unnecessary and all will create the code that throws CCE at runtime.
However, with this modification, the compiler will also detect that the subsequent code is bogus:
1. ERROR in /tmp/TestCast.java (at line 10)
if (keyId instanceof String)
Incompatible conditional operand types Long and String
2. ERROR in /tmp/TestCast.java (at line 11)
id = new Long((String) keyId);
Cannot cast from Long to String
Having a CCE at the loop header means, the subsequent code will never be entered with a String value. Hence the if-then part is nonsense, and a good compiler will detect that, unless you trick the compiler with declaring keyId as Object.
best,
Stephan
Re: ClassCastException with Java compiler, but not with Eclipse compiler???? [message #1504616 is a reply to message #1504604] |
Tue, 09 December 2014 12:04 |
Mathieu MARCIACQ Messages: 4 Registered: December 2014 |
Yes, fully agree about getting error during code edition....
But as I said, I can't change code.....
What i was looking for is a way to get Eclipse have same compilation behavior as JavaC 1.6.....And so that when I run my test, I get the exception throwed.....
It's a very huge software, with this kind of errors potentially in multiple places, on which several peoples are involved.
At the moment, Eclipse only display a warning for such bad code.
And if the <evil> programmer does such bad programming, and ignore the warning, all will runs fine on Eclipse, he will never see that a problem will occurs on the final software version, compiled with JavaC....
So, understanding your answers, I don't have any way to get Eclipse behavior 100% same as JavaC on this point....So we will teach to the team to avoid this kind of programmation, and hope they will do it....
Thanks for your help!
Current Time: Thu Mar 28 20:53:19 GMT 2024
Powered by FUDForum. Page generated in 0.03671 seconds
