Home » Archived » BIRT » Cannot open the connection for the driver Oracle DB
Cannot open the connection for the driver Oracle DB [message #1499626] Fri, 05 December 2014 04:21 Go to next message
I created report project in Eclipse Birt with some reports (Version: 4.3.0., Windows 7)
The data source is an Oracle database . In the WEB viewer, the reports display with data ok.
Runtime for Birt is Tomcat server 7, Oracle DB is the same.
I copied ojdbc14.jar (with its directory) from pc to the directory:
/home/apache-tomcat-7.0.42/webapps/BIRT-Viewer/WEB-INF/lib/org.eclipse.birt.report.data.oda.jdbc_4.3.0.v201306041519/drivers,
I installed BIRT viewer, sample report displays ok,
But my reports do not display for error:
Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: There is an error in get connection, ORA-01017: invalid username/password; logon denied
I am a newbie in Birt, please help.
Re: Cannot open the connection for the driver Oracle DB [message #1500325 is a reply to message #1499626] Fri, 05 December 2014 17:00 Go to previous messageGo to next message
This jar file should be put just under WEB-INF/lib folder: the subfolder you mentionned is OK with Eclipse designer, but not with a Tomcat server.
Furthermore with Tomcat it is highly recommended to use a "Connection Pool" rather than a direct JDBC access. If you setup a such pool, you won't have to deal with Oracle logins / passwords of the server in birt reports, among other huge benefits.
[Updated on: Fri, 05 December 2014 17:01] by Moderator
Re: Cannot open the connection for the driver Oracle DB [message #1500667 is a reply to message #1500325] Sat, 06 December 2014 00:02 Go to previous messageGo to next message
Smile
Thanks for the help Donino
Can you please provide the steps for creating "Connection Pool" in Tomcat and the way to use it in birt .
Thanks in Advance
Re: Cannot open the connection for the driver Oracle DB [message #1501046 is a reply to message #1500667] Sat, 06 December 2014 07:47 Go to previous message
There are a couple of Google links describing how to do this in Tomcat , please be more specific about which problems you encounter. By the way you should download and install PSI probe in Tomcat, this is useful beyond measure to test connections pools and diagnose issues.
Previous Topic:No Euro Symbol
Next Topic:BIRT 371 report running fine on BIRT Designer but running on taking long time to run
Current Time: Sun Jul 13 11:42:46 EDT 2025
Powered by FUDForum. Page generated in 0.05037 seconds
