Re: Workspace image not found in another eclipse instance [message #1498525 is a reply to message #1498455] |
Thu, 04 December 2014 13:19 |
Le 04/12/2014 13:15, Steven Kauffmann a écrit :
> Hi all,
Hi Steven,
> In my design I have defined a sub node with a workspace image style. The
> workspace image path is set to a svg file pointing to a certain
> directory in my current workspace. When I use my defined viewpoint in
> new environment that is pointing to another workspace the svg file
> cannot be found.
How do you use it in another workspace ? Is it deployed as a plugin ?
The Viewpoint Specification Model is intended to be defined in a
Viewpoint Specification Project which is a standard Eclipse plugin
project and can be deployed/installed in an Eclipse bundle.
> I have already included the image folder in the build configuration but
> this doesn't make any difference. What am I doing wrong?
In the Interaction sample (used in tests and available on the Sirius Git
repository), we define an image and it is well available after build and
installation. We put the following path in the Workspace Image Path
property section :
/org.eclipse.sirius.sample.interactions.design/description/eol.png to
reference the eol.png image from the description folder of the
org.eclipse.sirius.sample.interactions.design plugin.
> Best regards
> Steven
Maxime - Obeo
Need professional services for Sirius?
Maxime Porhel - Obeo
FUDForum. Page generated in 0.04127 seconds
