Newbie question: getting started & tutorial [message #27048] |
Wed, 10 December 2008 15:29 |
Michiel Verhoef Messages: 2 Registered: July 2009 |
Hi all,
Either I have stumbled upon a bug or I am doing something horribly wrong
here. In any case I am not able to do a few things that look pretty
straightforward from the tutorial.
First some figures:
JWT version: 0.5.0
Eclipse Ganymede version 3.4.1, build Id M20080911-1700
AgilPro Simulator 1.5.0
Java JRE
running on XP professional
I installed JWT via the Software Updates option in Eclipse and downloaded
the AgilPro from the sourceforge site. Although the tutorial PDF is for
the JWT 0.4.0 version I figured it should be okay to start from there,
having a bit of previous workflow experience with Staffware and Oracle
workflow systems.
After trying to run my first dummy workflow in the AgilPro simulator (the
workflow was the demo one in the tutorial) things started to go wrong: I
could not add an Edge (Reference or Activity) to my workflow. I was able
to do this before, but I forgot one (the edge between the Role and the
Action). Like I said, after executing it (and getting a proper error
message) things simply ended.
Even after restarting Eclipse and, for just-trying-out-sake, my PC I still
cannot add any (Reference/Activity) edges. I did try to throw away my
workflow and create a new one, even threw away my workspace.
What am I doing wrong here? Any help or suggestions would be greatly
appreciated.
Thanks in advance,
Michiel
Re: Newbie question: getting started & tutorial [message #27129 is a reply to message #27048] |
Wed, 10 December 2008 16:32 |
Originally posted by: mickael.istria.openwide.fr
Hello Michiel,
Since adding a reference is anything but "horribly wrong", I strongly
think you faced a bug ;)
Could you please open a bug report on Eclipse bugzilla to describe this
stange behavior? It might also be useful that you attach your
[workspace]/.metadata/.log file (or a compressed archive if it is too huge).
Then we'll try to fix it in priority (since it happens with the
tutorial...).
Thanks in advance.
Mickael
Michiel Verhoef a écrit :
> Hi all,
> First some figures:
> JWT version: 0.5.0
> Java JRE
> downloaded the AgilPro from the sourceforge site. Although the tutorial
> PDF is for the JWT 0.4.0 version I figured it should be okay to start
> from there, having a bit of previous workflow experience with Staffware
> and Oracle workflow systems.
> (the workflow was the demo one in the tutorial) things started to go
> wrong: I could not add an Edge (Reference or Activity) to my workflow. I
> was able to do this before, but I forgot one (the edge between the Role
> and the Action). Like I said, after executing it (and getting a proper
> error message) things simply ended.
> still cannot add any (Reference/Activity) edges. I did try to throw away
> my workflow and create a new one, even threw away my workspace.
> appreciated.
> Thanks in advance,
> Michiel
FUDForum. Page generated in 0.02987 seconds
