Home » Language IDEs » Orion » Embedding The Orion Editor
Embedding The Orion Editor [message #1488369] Wed, 26 November 2014 14:47 Go to next message
Michele Di Biase is currently offline Michele Di BiaseFriend
Hello everyone,
I am writing for some advice and / or clarification on a sample editor for eclipse orion
Visiting the site "planetorion.org" I stopped studying an article "Examples of Embedding The Orion Editor".
http://planetorion.org/news/2012/06/examples-of-embedding-the-orion-editor/
These examples, especially Embedded editor example, are used for my project: to create an editor, writing Java code, is in possession of content assist, syntax highlighting, error annotations.
I cloned the project on my space orion, but was not able to change the editor.
How can I change the code? Have you any suggestions? Otherwise there are other projects that have the same structure?
tnk
Re: Embedding The Orion Editor [message #1491067 is a reply to message #1488369] Fri, 28 November 2014 17:40 Go to previous message
John Arthorne is currently offline John ArthorneFriend
Hi Michele, I'm not sure I understand your question. So you have tried out these examples directly and now you want to copy them into your application and modify them? You would just need to clone the "Orion client" git repository, and then copy out the scripts you need into your own project/repository. Can you clarify what part you are stuck on, and we can try to help you out!
See also these other posts on how to use/embed the Orion editor:
http://planetorion.org/news/2013/02/embed-the-latest-orion-editor-in-your-code-in-2-steps/
http://planetorion.org/news/2013/03/use-the-orion-editor-in-your-blog/
Previous Topic:Orion theme support in Orion 7
Next Topic:Building and Deploying Orion
Current Time: Fri Oct 23 22:32:09 GMT 2020
Powered by FUDForum. Page generated in 0.01456 seconds
