Re: Installing IDE for Java Developers [message #268223 is a reply to message #268221] |
Fri, 30 January 2009 16:18 |
Originally posted by: newsgroups.eclipse.org-peter.palaga.drgarbage.com
Jerry Carlson wrote:
> I already have eclipse installed on my computer, it was installed when
> Dialog Designer from Avaya was installed. But now I would like to
> install the IDE for Java Developers. I am unable to use the update
> facility in Eclipse because of the firewall settings where I work. I can
> download it from the download page, so how do I install it.
Jerry,
If your machine at work can at least go through proxy (ask your network
administrator), this guide should help you to configure Eclipse to use
the proxy:
http://www.drgarbage.com/eclipse-proxy-configuration-guide.h tml
Peter
Peter Palaga
Re: Installing IDE for Java Developers [message #268233 is a reply to message #268221] |
Fri, 30 January 2009 17:54 |
Installing Eclipse (on Windows at least) is just a matter of unzipping
it and running the eclipse.exe executable. It will prompt you for a
location to create a workspace in, which you might want to change from
the default.
The only other step that is hihgly recommended before running Eclipse is
to tell it specifically what JVM to run in (a JDK, as opposed to a JRE,
is best if you're doing Java development). See this wiki page for the
details: http://wiki.eclipse.org/Eclipse.ini
Hope this helps,
Eric
FUDForum. Page generated in 0.07999 seconds
