Re: [buckminster-dev] Project cannot be built? [message #26576] |
Thu, 09 October 2008 06:24 |
Hi Mark,
Is there any way for me to reproduce this problem?
- thomas
Addleman, Mark J wrote:
> Thomas -
> I believe we are running the latest version of Buckminster on our
> headless build server where we encountered the problem. Here is the
> result of the listsite command:
> [addma03@ussjcpdc-p01 buckminster]$ ./buckminster listsite .
> Features:
> org.eclipse.buckminster.core.headless.feature_1.1.0.r09567
> (Buckminster - Core Headless)
> org.eclipse.buckminster.cvs.headless.feature_1.0.0.r09528 (Buckminster
> - CVS support for headless operation)
> org.eclipse.buckminster.maven.feature_1.1.0.r09568 (Buckminster -
> Maven support)
> org.eclipse.buckminster.pde.headless.feature_1.1.0.r09558 (Buckminster
> - PDE support for headless operation)
> org.eclipse.buckminster.product_1.1.0.r09505 (Buckminster Product)
> org.eclipse.buckminster.subversive.headless.feature_1.0.0.r0 9526
> (Buckminster - Subversive based SVN support for headless operation)
> Although the plugin set is different in the IDE, it looks like the
> versions are the same.
> I ran an experiment: I removed org.eclipse.osgi.services from our
> feature and did an IDE build. That was successful. Interestingly, even
> though services was not listed anywhere in our feature or product
> definitions, it was included in build result. The headless build failed
> when compiling org.osgi.equinox.app because it couldn't find any bundle
> to supply the package imports.
> -----Original Message-----
> From: Addleman, Mark J
> Sent: Wednesday, October 08, 2008 7:50 AM
> To: 'Buckminster developer discussions'
> Subject: RE: [buckminster-dev] Project cannot be built?
> Hi, Thomas -
> Thanks for the quick response. I'm traveling today with limited access
> to our systems, so I can't verify the Buckminster versions but I'll do
> that as soon as I get a chance.
> A couple of questions:
> Does the Buckminster headless provide an "update" command similar to
> Eclipse Help->Software Updates?
> I believe the org.eclipse.osgi.services bundle is not a fragment.
> org.eclipse.equinox.app doesn't declare a dependency on services, rather
> app imports the packages defined in services. Will Buckminster figure
> out the proper ordering?
> From: buckminster-dev-bounces@eclipse.org
> [mailto:buckminster-dev-bounces@eclipse.org] On Behalf Of Thomas
> Hallgren
> Sent: Wednesday, October 08, 2008 12:36 AM
> To: Buckminster developer discussions
> Subject: Re: [buckminster-dev] Project cannot be built?
> Hi Mark,
> What version of Buckminster are you using? Apparently the fragments are
> built before their host bundle. I can see that from looking at the build
> of the m365.messaging.receiver.feature. It has entries like:
> lib.commons_codec:osgi.bundle$1.0.0#OSGi#target.fragments
> lib.commons_codec:osgi.bundle$1.0.0#OSGi#bundle.jar
> and the pattern is the same every bundle. This problem was recently
> resolved. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=247005
> Could it be that you are using the latest buckminster pde feature in
> your IDE but not in your headless setup?
> Regards,
> Thomas Hallgren
>> I am having trouble building org.eclipse.equinox.app using headless
>> Buckminster. I can resolve the entire project with my query, but when
>> I try to perform the create action for my product, the
>> org.eclipse.equinox.app fails because its prerequisite
>> org.eclipse.osgi.services isn't built. It then says, "Cleaning and
>> building all projects is recommended." Weirdly, the corresponding
>> process works in the IDE.
>> Attached are the build scripts I'm using along with the output of the
>> build.
>> _______________________________________________
>> buckminster-dev mailing list
>> buckminster-dev@eclipse.org
>> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
FUDForum. Page generated in 0.03065 seconds
