Where to begin? [message #26564] |
Wed, 10 August 2005 16:17 |
Originally posted by: gusvaz.fing.edu.uy
Hi, I'm new in this news and I have just discovered th TPTP. I want to know
more about it. Where do I begin? By wich documentation?
Thanks in advance.
Gustavo V
Re: Where to begin? [message #26567 is a reply to message #26564] |
Wed, 17 August 2005 03:47 |
Originally posted by: Ali_Mehregani_-_amehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 0014D91685257060_=
Content-Type: text/plain; charset="US-ASCII"
There are three different sources that you can begin from:
1) Go to the main home page: www.eclipse.org/tptp > click on
documentation and start with one the introductory documents designed for
users. I recommend:
a) An Introduction in Profiling Java Applications (if you're interested in
profiling)
b) An Introduction to the Generic Log Adapter (if interested in logging)
2) You can review the documentation available from the help content. Look
at:
a) TPTP Tester Guide (if interested in the test framework)
b) Monitoring and Analyzing Performance (if interested in profiling,
logging, probekit, symptom database, and etc...)
3) (Probably the easiest one) Download and create TPTP Examples and read
their respective documentation to understand each example.
Good Luck
Content-Type: text/html; charset="US-ASCII"
<br><font size=3 face="Times New Roman">There are three different sources
that you can begin from:</font>
<br>
<br><font size=3 face="Times New Roman">1) Go to the main home page:
</font><font size=3 color=blue face="Times New Roman"><u>www.eclipse.org/tptp</u></font><font size=3 face="Times New Roman">
> click on documentation and start with one the introductory documents
designed for users. I recommend:</font>
<br><font size=3 face="Times New Roman">a) An Introduction in Profiling
Java Applications (if you're interested in profiling)</font>
<br><font size=3 face="Times New Roman">b) An Introduction to the Generic
Log Adapter (if interested in logging)</font>
<br><font size=3 face="Times New Roman"> </font>
<br><font size=3 face="Times New Roman">2) You can review the documentation
available from the help content. Look at:</font>
<br><font size=3 face="Times New Roman">a) TPTP Tester Guide (if interested
in the test framework)</font>
<br><font size=3 face="Times New Roman">b) Monitoring and Analyzing Performance
(if interested in profiling, logging, probekit, symptom database, and etc...)</font>
<br><font size=3 face="Times New Roman">3) (Probably the easiest one) Download
and create TPTP Examples and read their respective documentation to understand
each example.</font>
<br>
<br><font size=3 face="Times New Roman"> Good Luck</font>
--=_alternative 0014D91685257060_=--
FUDForum. Page generated in 0.08149 seconds
