Home » Modeling » EMF » XSD to dynamic meta model?
XSD to dynamic meta model? [message #1479925] Wed, 19 November 2014 21:19 Go to next message
Erdal Karaca is currently offline Erdal KaracaFriend
Hi all,
Is it possible to transform an XSD to a dynamic meta model in memory at run-time without code generation, then (at run-time) instantiate models from it using an XML instance?
Anyone did that before and can tell about performance or any other issues/drawbacks?
Thanks.
Re: XSD to dynamic meta model? [message #1479930 is a reply to message #1479925] Wed, 19 November 2014 21:20 Go to previous messageGo to next message
With "using an XML instance" I mean that I have an XML instance/file conforming to the XSD that I want to de-serialize using the dynamic meta model.
Erdal Karaca wrote on Wed, 19 November 2014 22:19
Hi all,
Thanks.
Re: XSD to dynamic meta model? [message #1480408 is a reply to message #1479930] Thu, 20 November 2014 06:41 Go to previous message
org.eclipse.emf.ecore.xmi.impl.GenericXMLResourceImpl.GenericXMLResourceImpl(URI)
does that kind of thing. Probably
org.eclipse.emf.ecore.xmi.impl.GenericXMLResourceFactoryImpl.createResource(URI)
should be creating that type of resource, but if I changed it I'd likely
break existing users.
> meta model.
>> Hi all,
>> issues/drawbacks?
>> Thanks.
Previous Topic:EPackage with no ResourceSet?
Next Topic:(Re)using model elements in other models
Current Time: Sat Jun 06 15:19:32 GMT 2020
Powered by FUDForum. Page generated in 0.01518 seconds
