Re: MoDisco installation for UML reverse engineering [message #1479511 is a reply to message #1479435] |
Wed, 19 November 2014 13:40 |
Hugo Bruneliere Messages: 674 Registered: July 2009 |
By default (i.e. using the releases update sites or the specific interface from the Modeling bundle), you will get the full MoDisco SDK including the provided UML reverse engineering support from Java source code (via KDM).
Note that this is not "polluting" in any way your Eclipse workbench with menus or views you don't want to use or see.
If you want to only install a subset of these plugins, I encourage you to take a deeper look the project documentation in order to identify the plugins you actually need.
Hugo Bruneliere, PhD
NaoMod team (IMT Atlantique & LS2N-CNRS)
Nantes - France
FUDForum. Page generated in 0.03223 seconds
