Re: Problems while installing MARTE over Payrus [message #1691858 is a reply to message #1691782] |
Fri, 10 April 2015 08:07 |
Camille Letavernier Messages: 952 Registered: February 2011 |
Hi Ali,
The "Install additional components" may fail on one of the following issues:
- It is already installed, because you installed "Papyrus Extra", which includes all additional components
- There is a missing dependency, e.g. you're trying to install Marte Luna SR2 (1.0.2) on top of Papyrus Luna SR1 (1.0.1)
In the first case, nothing to do; in the second case, you need to use "Check for updates" before installing Marte. The second case used to happen because Eclipse Modeling Luna SR2 were installing Papyrus Luna SR1 (Instead of Papyrus Luna SR2), causing these dependency issues
If none of these solutions work, you can use "Help > Install new software", and use the following update site for Papyrus Luna:
http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/luna/extra
You may need to uncheck "Group items by category" in order to install only Marte Components (Instead of all extra components, which is usually too much)
HTH,
Camille
Camille Letavernier
FUDForum. Page generated in 0.03369 seconds
