Home » Eclipse Projects » Sirius » Custom Edge Styling - Avoid obstructions
Custom Edge Styling - Avoid obstructions [message #1478338] |
Tue, 18 November 2014 15:52 |
Stéphane Seyvoz Messages: 21 Registered: October 2014 |
The issue
Sirius' provided layouts can create representations where Edges can go over/across graphical nodes/container nodes, whereas the underlying GMF "Avoid Obstructions" setting could prevent that.
I tried to enable such a thing, but didn't manage.
Tentative 1: The SiriusViewProvider-like way
I tried to implement a custom class similar to the SiriusViewProvider, using the org.eclipse.gmf.runtime.diagram.core.viewProviders extension point, to implement my own Class<?> getEdgeViewClass(int visualID) method returning a custom variation of DEdgeViewFactory (see SiriusViewProvider line 340 with Sirius 2.0.0, 341 with the link provided below).
The original DEdgeViewFactory setManahattanRoutingStyle and setTreeRoutingStyle methods configure the routing with setJumpLinkType, setJumpLinkStatus, setRouting, but not setAvoidObstructions or setClosestDistance (see RoutingStyle interface).
Quick resources links (maybe not up-to-date) for convenience:
- eclipse.googlesource.com/sirius/org.eclipse.sirius/+/5cf53378e4a084aefb90d9648d5db61d83881f58/plugins/org.eclipse.sirius.diagram/src/org/eclipse/sirius/diagram/internal/providers/SiriusViewProvider.java
- eclipse.googlesource.com/sirius/org.eclipse.sirius/+/0745304c5dcfd33794d483b3de844eaa02024b10/plugins/org.eclipse.sirius.diagram/src/org/eclipse/sirius/diagram/internal/view/factories/DEdgeViewFactory.java
I wanted to refine that.
I set my extension point with a High priority, in a way like what is done in Sirius internally for SiriusViewProvider, in the org.eclipse.sirius.diagram.ui module. My classes were instantiated, however the getNodeViewClass methods were called, but never the getEdgeViewClass ones. I investigated and discovered in the documentation that only Nodes can be customized yet, ok, let's call it normal (but frustrating).
So I investigated further.
Tentative 2: The "org.eclipse.sirius.diagram.canonicalSynchronizerFactoryOverride" extension point
This extension point was introduced in Sirius 2.0.0 (see Sirius Release Notes, API changes section).
Going upwards in the call hierarchy, I discovered that in Sirius, the SiriusViewProvider object creation is hardcoded in AbstractCanonicalSynchronizer (extended by DDiagramCanonicalSynchronizer), and that hence the AbstractCanonicalSynchronizer#createViews method always calls the default createEdge method line 292 (whereas nodes are handled in another place in Sirius as well as there, allowing more flexibility).
So I decided to create my own custom CanonicalSynchronizerFactory and CanonicalSynchronizer classes, and to extend the org.eclipse.sirius.diagram.canonicalSynchronizerFactoryOverride extension point, and to override only what was needed to use my own ViewProvider, for my custom edges.
In the end, I discovered that it could not work for an even more frustrating reason.
The CanonicalSynchronizerFactory refers to an "instance" that is created by CanonicalSynchronizerFactoryImpl.init() which uses the mentioned new extension point, which sounds really nice, however the returned element is the first (result = contributedFactories.get(0) line 67), and as Sirius itself is contributing the extension point internally from its org.eclipse.sirius.diagram.ui module (see plugin.xml), the latter is always first, and mine is never used
- eclipse.googlesource.com/sirius/org.eclipse.sirius/+/b128eea5b782e5d1e3eb9642405fefff866ed0e7/plugins/org.eclipse.sirius.diagram/specific/org/eclipse/sirius/diagram/internal/refresh/AbstractCanonicalSynchronizer.java
Note: I didn't provide the CanonicalSynchronizerFactoryImpl from 2.0.0 version link since I couldn't find any online source matching the one from my installed Sirius SDK plugin.
Note 2: sorry about the "textual" links since I cannot post any yet, being a new user.
Conclusion
In the end, I don't know what to do.
Is it possible to do anything at the GMF level ?
How can I suggest any modification to the Sirius team ?
Maybe is there already a feature request for this somewhere in a tracker ?
Thank you !
[Updated on: Tue, 25 November 2014 16:06] Report message to a moderator
Re: Custom Edge Styling [message #1479379 is a reply to message #1478338] |
Wed, 19 November 2014 11:34 |
Le 18/11/2014 16:52, Stéphane Seyvoz a écrit :
> The issue
> "Avoid Obstructions" setting could allow that.
> provided below).
The SiriusViewProvider does not use the
org.eclipse.gmf.runtime.diagram.core.viewProviders extension point. So
you can not override Sirius class by this way.
> done in Sirius internally for SiriusViewProvider (in the
> org.eclipse.sirius.diagram.ui module). My classes were instantiated,
> getEdgeViewClass methods. I investigated and discovered in the
Where do you see in the documetation that "only Nodes can be customized
yet"?
> Tentative 2: The
> extension point
And in the same Release notes, it is said that "its only intended
implementer is the @org.eclipse.sirius.diagram.ui@ plug-in. It is used
by the diagram dialect's core to delegate to the UI plug-in the
canonical synchronizer logic, which depends on the UI." So it is
"normal" that your implementation is ignored.
> frustrating reason.
> always first, and mine is never used :(
The "original" source code is available here: [1]. The
eclipse.googlesource.com is only a mirror.
> being a new user.
> Conclusion
This is a feature request. Nothing in Sirius allows you to customize
these fields.
What is your need finally? Set the values "Avoid obstructions" and
"Closest distance" to true for all new edges?.
You can use the SessionEventBroker [2] to add a listener that detects
the creation of a new Edge and set the 2 properties. It is more a
workaround that a real solution.
You can find an example of SessionEventBroker usage in EcoreTools
project, line 127 of class EcoreToolsDesignPlugin [3].
You can propose gerrit review to the team but it is preferable to
discuss before about your needs through this forum or through a bugzilla
[4].
No, this is a new request. You can see all the current bugzilla for
Sirius project with [5].
> Thank you !
[1] http://git.eclipse.org/c/sirius/org.eclipse.sirius.git
[2]
http://git.eclipse.org/c/sirius/org.eclipse.sirius.git/plain/plugins/org.eclipse.sirius/src/org/eclipse/sirius/business/api/session/SessionEventBroker.java
[3]
http://git.eclipse.org/c/ecoretools/org.eclipse.ecoretools.git/tree/org.eclipse.emf.ecoretools.design/src/org/eclipse/emf/ecoretools/design/service/EcoreToolsDesignPlugin.java
[4] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Sirius
[5]
https://bugs.eclipse.org/bugs/buglist.cgi?list_id=10507820&product=Sirius&query_format=advanced
Laurent - Obeo
Need professional services for Sirius?
Laurent Redor - Obeo
Re: Custom Edge Styling [message #1479631 is a reply to message #1479379] |
Wed, 19 November 2014 15:48 |
Hi Laurent,
First, yes my main need is to set "Avoid obstructions", since it would a really great improvement. "Closest distance" may be needed later, but can be forgotten right now.
I thought about the GMF ViewProvider extension point, after finding this post: How to set Avoid obstructions and Closest distance on my connections by default, then tried to do something similar with Sirius.
Concerning your "Where do you see in the documentation that "only Nodes can be customized yet"?" question, I may have gotten confused by all the experiments I recently made with Sirius. I had also manipulated StyleConfigurations, and the Extensions - Provide Custom Style documentation says:
Quote:The StyleConfiguration mechanism is only available for ViewNode at the moment.
I extrapolated, a bit hastily I admit, that such a behavior may have applied a bit more widely to the project (as a matter of priority in development, for example). The fact that I could use a GMF extension-point-contributed ViewProvider "Node" methods and not the "Edge" ones at some point (I don't remember the details) comforted me in this idea. My apologies for the confusion.
I was aware of the "canonicalSynchronizerFactoryOverride" documented limitation... However, the introduction of such an extension point made me think there was a tendency to make it more flexible in the future (maybe not intended though ?), at quite a low cost. I just didn't know where to submit a request or contribution about that, so this forum looked the right place to start
Your message clarified that point, so thank you about that.
Concerning the technical workaround, I will have a try as a quickfix, and to the Bugzilla as well.
Thank you for the fast and clear answers !
[Edit] Link to the Bugzilla enhancement request: Bug 452310
[Updated on: Wed, 19 November 2014 16:22] Report message to a moderator
Re: Custom Edge Styling [message #1479708 is a reply to message #1479631] |
Wed, 19 November 2014 17:14 |
Le 19/11/2014 16:48, Stéphane Seyvoz a écrit :
> Hi Laurent,
> post: https://www.eclipse.org/forums/index.php/t/74589/, then tried to
> https://www.eclipse.org/sirius/doc/developer/extensions-provide_custom_style.html
> documentation says:
> Quote:
>> moment.
There is currently no planned work for this. This new extension point
has appeared during a global enhancement of "Sirius's modularization",
more particulary to clearly separate UI and non UI stuff [1].
> I just didn't know
> looked the right place to start :)
Let us know if you have any further question or issue.
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=439871
Laurent - Obeo
Re: Custom Edge Styling [message #1487138 is a reply to message #1479708] |
Tue, 25 November 2014 15:47 |
Just a message to state how things went during my experiment.
I implemented the "Avoid obstructions" thanks to the SessionEventBroker as recommended, as follows (if people are interested):
- Activator.java
- AvoidObstructionsEdgesStyleFixTrigger.java
License is LGPLv3.
A few remarks:
- The setting works fine for Edges to avoid Nodes and Container Nodes, however the Edges can still overlap with Bordered Nodes. Those do not seem to be considered as "obstructing" by GMF, according to Sirius configuration/behavior apparently. I don't know how to overcome this limitation... Any suggestion would be welcome.
- The "notifyAddSession" is ok at session creation time but the trigger would not be registered with existing sessions (restarting the target Eclipse for example), so it's important to implement the "notify" method, however there's a number of available notifications, I may not have found the best ones to handle (further testing will tell).
- The "transaction domain" wasn't needed compared to the provided example link, since we do not touch the model, only style info.
Hope it helps, best regards !
[Updated on: Tue, 25 November 2014 16:11] Report message to a moderator
Re: Custom Edge Styling [message #1488266 is a reply to message #1487138] |
Wed, 26 November 2014 13:04 |
Thanks for your feedback. Few remarks below:
> https://github.com/StephaneSeyvoz/mindEd/blob/8055220b258ffbb6fa9e0b105aae83d2399d4050/org.ow2.mindEd.adl.sirius/src/org/ow2/mindEd/adl/sirius/Activator.java
> https://github.com/StephaneSeyvoz/mindEd/blob/8055220b258ffbb6fa9e0b105aae83d2399d4050/org.ow2.mindEd.adl.sirius/src/org/ow2/mindEd/adl/sirius/style/AvoidObstructionsEdgesStyleFixTrigger.java
> A few remarks that came to me:
> - The setting works fine and Edges go around my Nodes and Container
> configuration/behavior apparently: I don't know how to overcome this
No idea. Some investigations would be necessary...
> have found the best ones to check (further testing will tell).
It's wrong. The style is stored in the GMF notation model part. So it
must be made inside a RecordingCommand to be correctly managed by
undo/redo, rollback, ...
The "filter" for the ModelChangeTrigger does not detect only the Edge
creation, so this preCommitListener will be called too often (at each
edge modification).
Laurent - Obeo
Re: Custom Edge Styling [message #1489609 is a reply to message #1489405] |
Thu, 27 November 2014 14:19 |
Le 27/11/2014 11:37, Stéphane Seyvoz a écrit :
> I've had issues happening recently on layers activation/deactivation,
> when GMF tries to compute new paths, with stale edges
> NullPointerExceptions on "avoid obstructions" that indicate that the
> actual solution can lead to dirty internal states.
> So I strongly agree with you that a domain transaction /
> RecordingCommand will be cleaner indeed, I'll improve the solution and
> post the result as well.
> I understand about the edge filter part not being optimal, I don't know
> what to do about it though...
something like:
input.getEventType() == Notification.ADD && input.getNewValue()
instanceof Edge
and probably the case of input.getEventType() == Notification.ADD_MANY
to handle
Laurent - Obeo
Re: Custom Edge Styling [message #1490679 is a reply to message #1489609] |
Fri, 28 November 2014 10:45 |
New version using a RecordingCommand:
Activator.java
EnableAvoidObstructionsEdgesRoutingStyleCommand.java
I have a problem with Layers though, that already existed with the previous version: When disabling a layer from my VSM, some edges have to be removed/erased, and then the following exception appears:
at org.eclipse.draw2d.ShortestPathConnectionRouter.processStaleConnections(ShortestPathConnectionRouter.java:184)
at org.eclipse.draw2d.ShortestPathConnectionRouter.getPathsAfterRouting(ShortestPathConnectionRouter.java:298)
at org.eclipse.gmf.runtime.draw2d.ui.internal.routers.ObliqueRouter.routeAroundObstructions_GEF(ObliqueRouter.java:296)
at org.eclipse.gmf.runtime.draw2d.ui.internal.routers.ObliqueRouter.calculateBendPoints(ObliqueRouter.java:227)
at org.eclipse.gmf.runtime.draw2d.ui.internal.routers.ObliqueRouter.routeBendpoints(ObliqueRouter.java:206)
at org.eclipse.gmf.runtime.draw2d.ui.internal.routers.ObliqueRouter.route(ObliqueRouter.java:195)
at org.eclipse.draw2d.PolylineConnection$RoutingNotifier.route(PolylineConnection.java:371)
at org.eclipse.draw2d.PolylineConnection.layout(PolylineConnection.java:176)
at org.eclipse.sirius.diagram.ui.edit.api.part.AbstractDiagramEdgeEditPart$ViewEdgeFigure.layout(AbstractDiagramEdgeEditPart.java:671)
at org.eclipse.draw2d.Figure.validate(Figure.java:1896)
at org.eclipse.draw2d.Figure.validate(Figure.java:1898)
at org.eclipse.draw2d.FreeformViewport$FreeformViewportLayout.calculatePreferredSize(FreeformViewport.java:25)
at org.eclipse.draw2d.AbstractLayout.getPreferredSize(AbstractLayout.java:110)
at org.eclipse.draw2d.AbstractHintLayout.getPreferredSize(AbstractHintLayout.java:90)
at org.eclipse.draw2d.Figure.getPreferredSize(Figure.java:807)
at org.eclipse.draw2d.ScrollPaneSolver.solve(ScrollPaneSolver.java:82)
at org.eclipse.draw2d.FigureCanvas.layoutViewport(FigureCanvas.java:325)
at org.eclipse.draw2d.FigureCanvas.access$4(FigureCanvas.java:323)
at org.eclipse.draw2d.FigureCanvas$3.notifyValidating(FigureCanvas.java:292)
at org.eclipse.draw2d.UpdateManager.fireValidating(UpdateManager.java:143)
at org.eclipse.sirius.diagram.ui.tools.internal.part.SiriusDiagramGraphicalViewer$ToggleUpdateManager.performValidation(SiriusDiagramGraphicalViewer.java:211)
at org.eclipse.draw2d.DeferredUpdateManager.performUpdate(DeferredUpdateManager.java:190)
at org.eclipse.sirius.diagram.ui.tools.internal.part.SiriusDiagramGraphicalViewer$ToggleUpdateManager.performUpdate(SiriusDiagramGraphicalViewer.java:195)
at org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(DeferredUpdateManager.java:44)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:136)
... 37 more
I'm trying to do an implementation where I would disable the "avoid obstructions" on edge REMOVE / REMOVE_MANY, with no success yet.
[Updated on: Fri, 28 November 2014 10:59] Report message to a moderator
Current Time: Wed Apr 24 23:58:22 GMT 2024
Powered by FUDForum. Page generated in 0.03816 seconds
