Home » Newcomers » Newcomers » When I try to open Eclipse the next day, it won't open on my Mac(I need help)
When I try to open Eclipse the next day, it won't open on my Mac [message #1474510] Sat, 15 November 2014 13:33 Go to next message
James Daykin is currently offline James DaykinFriend
Using an iMac with all the latest updates installed. When I first install Eclipse, it works fine, it's only the next day when I try to open it, it comes up with a message saying it unexpectedly quit and this just continues to happen so wondered if anyone could help me out? Cheers
Re: When I try to open Eclipse the next day, it won't open on my Mac [message #1474516 is a reply to message #1474510] Sat, 15 November 2014 13:36 Go to previous messageGo to next message
Denis Roy is currently offline Denis RoyFriend
In your eclipse directory there should be a log file...l Can you paste the latest entries from it?
Denis Roy
Eclipse Webmaster -- webmaster@eclipse.org
Re: When I try to open Eclipse the next day, it won't open on my Mac [message #1474521 is a reply to message #1474516] Sat, 15 November 2014 13:40 Go to previous messageGo to next message
Denis Roy wrote on Sat, 15 November 2014 13:36
What would the name of this file be?
Re: When I try to open Eclipse the next day, it won't open on my Mac [message #1494517 is a reply to message #1474510] Mon, 01 December 2014 14:44 Go to previous messageGo to next message
Lindsey Jones is currently offline Lindsey JonesFriend
I am also having the identical problem. Repeatedly I get a crash and the application will never open.
Re: When I try to open Eclipse the next day, it won't open on my Mac [message #1494535 is a reply to message #1474521] Mon, 01 December 2014 14:55 Go to previous messageGo to next message
James Daykin wrote on Sat, 15 November 2014 08:40
In your workspace diretory, look for .metadata/.log
Denis Roy
Re: When I try to open Eclipse the next day, it won't open on my Mac [message #1494541 is a reply to message #1494535] Mon, 01 December 2014 15:02 Go to previous messageGo to next message
This is my log file
!SESSION 2014-11-19 13:08:26.734 -----------------------------------------------
eclipse.buildId=4.4.1.M20140925-0400
java.version=1.6.0_65
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product -keyring /Users/lindseyjones/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.java.product -keyring /Users/lindseyjones/.eclipse_keyring -showlocation
!ENTRY org.eclipse.m2e.logback.configuration 2 0 2014-11-19 13:08:54.852
!MESSAGE Exception while setting up logging:org.eclipse.osgi.internal.framework.EquinoxConfiguration$1 cannot be cast to java.lang.String
!STACK 0
java.lang.ClassCastException: org.eclipse.osgi.internal.framework.EquinoxConfiguration$1 cannot be cast to java.lang.String
at org.eclipse.m2e.logback.configuration.LogHelper.logJavaProperties(LogHelper.java:26)
at org.eclipse.m2e.logback.configuration.LogPlugin.loadConfiguration(LogPlugin.java:189)
at org.eclipse.m2e.logback.configuration.LogPlugin.configureLogback(LogPlugin.java:144)
at org.eclipse.m2e.logback.configuration.LogPlugin.access$2(LogPlugin.java:107)
at org.eclipse.m2e.logback.configuration.LogPlugin$1.run(LogPlugin.java:62)
at java.util.TimerThread.mainLoop(Timer.java:512)
at java.util.TimerThread.run(Timer.java:462)
!ENTRY org.eclipse.core.net 1 0 2014-11-19 13:08:56.422
!MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences
!ENTRY org.eclipse.equinox.p2.operations 4 0 2014-11-19 13:11:19.109
!MESSAGE Operation details
!SUBENTRY 1 org.eclipse.equinox.p2.operations 4 10050 2014-11-19 13:11:19.109
!MESSAGE Cannot complete the request. See the error log for details.
!SUBENTRY 1 org.eclipse.equinox.p2.operations 2 10004 2014-11-19 13:11:19.109
!MESSAGE "TFS plug-in for Eclipse" will be ignored because a newer version is already installed.
!MESSAGE "TFS plug-in for Eclipse Language Pack" will be ignored because a newer version is already installed.
!ENTRY org.eclipse.equinox.p2.operations 4 0 2014-11-19 13:11:19.113
!SUBENTRY 1 org.eclipse.equinox.p2.operations 4 10050 2014-11-19 13:11:19.113
!SUBENTRY 1 org.eclipse.equinox.p2.operations 2 10004 2014-11-19 13:11:19.113
!SESSION 2014-11-24 09:35:25.544 -----------------------------------------------
!ENTRY org.eclipse.m2e.logback.configuration 2 0 2014-11-24 09:35:31.288
!STACK 0
!ENTRY org.eclipse.core.net 1 0 2014-11-24 09:35:32.889
!SESSION 2014-11-25 11:17:34.859 -----------------------------------------------
!ENTRY org.eclipse.m2e.logback.configuration 2 0 2014-11-25 11:17:53.562
!STACK 0
!ENTRY org.eclipse.core.net 1 0 2014-11-25 11:17:55.229
Re: When I try to open Eclipse the next day, it won't open on my Mac [message #1494605 is a reply to message #1494541] Mon, 01 December 2014 16:03 Go to previous message
Lindsey Jones wrote on Mon, 01 December 2014 10:02
!STACK 0
Looks like a bug was fixed shortly after the release you're using:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=445122
Perhaps try one of the developer builds:
http://eclipse.org/downloads/index-developer.php
Denis Roy
Previous Topic:Which eclipse archive version is right for me?
Next Topic:Working with WMS
Current Time: Thu Oct 29 03:21:51 GMT 2020
Powered by FUDForum. Page generated in 0.05181 seconds
