Home » Modeling » EMF » [Xcore] [Texo] NPE exception occurring whenever typing in editor
[Xcore] [Texo] NPE exception occurring whenever typing in editor [message #1473886] Sat, 15 November 2014 01:12 Go to next message
Anton Hughes is currently offline Anton HughesFriend
Member
I'm trying do some xcore coding, and have just installed xcore into a fresh Luna installation.
Whenver I type in the UI I get a error notice popup and disrupt the follow.
The error is:
An internal error occurred during: "Xtext validation".
The error log shows:
at org.eclipse.emf.ecore.xcore.scoping.XcoreLogicalContainerAwareReentrantTypeResolver.getExtendedClass(XcoreLogicalContainerAwareReentrantTypeResolver.java:21)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.addExtensionFieldsToMemberSession(LogicalContainerAwareReentrantTypeResolver.java:800)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.addExtensionFieldsToMemberSession(LogicalContainerAwareReentrantTypeResolver.java:803)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.addExtensionsToMemberSession(LogicalContainerAwareReentrantTypeResolver.java:769)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.prepareMembers(LogicalContainerAwareReentrantTypeResolver.java:344)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._doPrepare(LogicalContainerAwareReentrantTypeResolver.java:340)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.doPrepare(LogicalContainerAwareReentrantTypeResolver.java:328)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.prepare(LogicalContainerAwareReentrantTypeResolver.java:322)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:526)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:132)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:119)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultBatchTypeResolver$1.reentrantResolve(DefaultBatchTypeResolver.java:91)
at org.eclipse.xtext.xbase.typesystem.internal.CompoundReentrantTypeResolver.reentrantResolve(CompoundReentrantTypeResolver.java:67)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$LazyResolvedTypes.resolveTypes(CachingBatchTypeResolver.java:79)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:56)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:1)
at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:36)
at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:127)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver.doResolveTypes(CachingBatchTypeResolver.java:52)
at org.eclipse.xtext.xbase.typesystem.internal.AbstractBatchTypeResolver.resolveTypes(AbstractBatchTypeResolver.java:55)
at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:64)
at org.eclipse.xtext.xbase.resource.BatchLinkableResource.resolveLazyCrossReferences(BatchLinkableResource.java:150)
at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:513)
at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:159)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:68)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:80)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:1)
at org.eclipse.xtext.util.concurrent.CancelableUnitOfWork.exec(CancelableUnitOfWork.java:25)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.internalReadOnly(XtextDocument.java:494)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.readOnly(XtextDocument.java:465)
at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:105)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.createIssues(ValidationJob.java:75)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.run(ValidationJob.java:64)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Is there anything I can do to prevent this error occuring?
[Updated on: Sat, 15 November 2014 06:43]
Report message to a moderator
Re: [Xcore] NPE exception occurring whenever typing in editor [message #1474155 is a reply to message #1473886] Sat, 15 November 2014 06:39 Go to previous messageGo to next message
Member
This seems to be a problem in the milestone release of Texo.
Re: [Xcore] NPE exception occurring whenever typing in editor [message #1474240 is a reply to message #1473886] Sat, 15 November 2014 08:15 Go to previous messageGo to next message
Anton,
Actually I just fixed that yesterday via
https://bugs.eclipse.org/bugs/show_bug.cgi?id=451208. It should be in
the next maintenance build once it's build via
http://download.eclipse.org/modeling/emf/emf/updates/2.10.x. If it's
the identical cause, ensuring that xcore.lib in on the classpath should
avoid the problem, i.e., a project created using the new Xcore Project
wizard has the classpath setup correctly up front.
On 15/11/2014 2:12 AM, Anton Hughes wrote:
> Hi
> follow.
> The error is:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
Ed Merks
Re: [Xcore] NPE exception occurring whenever typing in editor [message #1500520 is a reply to message #1474240] Sat, 06 December 2014 02:04 Go to previous message
Member
Thanks Ed, yes that fixed it Smile
Previous Topic:Can't Steer EType from XSD: Type vs Type1 vs Type2 Problems
Next Topic:CWM usage in EMF
Current Time: Thu May 06 11:06:28 GMT 2021
Powered by FUDForum. Page generated in 0.02327 seconds
