Eclipse 3.0 Problem Opening Wizard [message #265989] |
Mon, 09 August 2004 03:11 |
Originally posted by: MarkLarz.nospam.hotmail.com
I just installed Eclipse 3.0 and tried creating a new Java project and get
the following error:
The selected wizard could not be started.
Reason:
Plug-in org.eclipse.jdt.ui was unable to load class
org.eclipse.jdt.internal.ui.wizards.JavaProjectWizard
I am new to Eclipse/Java so I am not sure what to do to fix this.
Mark
Re: Eclipse 3.0 Problem Opening Wizard [message #265995 is a reply to message #265989] |
Mon, 09 August 2004 03:20 |
Originally posted by: Chris_Laffra.ca.ibm.com
This is strange. Should work. Did something go wrong during download
and first execution? Could you run "eclipse -clean" and see if that helps?
What does you log file say? (see http://eclipsefaq.org, FAQ 27).
Also check out FAQ 29.
Chris
"Mark" <MarkLarz@nospam.hotmail.com> wrote in message
news:cf6ps3$hl2$1@eclipse.org...
> Reason:
> Mark
Re: Eclipse 3.0 Problem Opening Wizard [message #265999 is a reply to message #265995] |
Mon, 09 August 2004 03:30 |
I did the eclipse -clean and still have the error. Here is the exported
error log info:
!ENTRY org.eclipse.osgi Aug 08, 2004 22:53:45.31
!MESSAGE An error occured while automatically activating bundle
org.eclipse.jdt.core (31).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.jdt.core.JavaCore.start() of bundle org.eclipse.jdt.core.
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(Bu
ndleContextImpl.java:975)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleConte
xtImpl.java:937)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.j
ava:421)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle
..java:293)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseCl
assLoader.java:110)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleL
oader.java:371)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.requir eClass(BundleLoa
der.java:336)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findRe quiredClass(Bund
leLoader.java:914)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader
..java:399)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(Abstra
ctClassLoader.java:93)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.getConstructor(Unknown Source)
at
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivatio
n(PluginDescriptor.java:403)
at
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(Plugin
Descriptor.java:359)
at
org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescripto
r.java:328)
at
org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivato
r.java:47)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleConte
xtImpl.java:958)
at
ndleContextImpl.java:954)
at
xtImpl.java:937)
at
ava:421)
at
..java:293)
at
assLoader.java:110)
at
oader.java:371)
at
..java:402)
at
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader
..java:307)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.jav
a:336)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBu
ndle.java:1313)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExte
nsion(ConfigurationElement.java:131)
at
nsion(ConfigurationElement.java:124)
at
nsion(ConfigurationElement.java:113)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:196)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java
:193)
at
org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eExecutableExten
sion(WorkbenchWizardElement.java:96)
at
org.eclipse.ui.internal.dialogs.NewWizardNewPage$6.createWiz ard(NewWizardNew
Page.java:740)
at
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$2.run(Wo rkbenchWizardNod
e.java:133)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:615)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$1.run(Wo rkbenchWizardNod
e.java:114)
at
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode.getWizar d(WorkbenchWizar
dNode.java:112)
at
org.eclipse.jface.wizard.WizardSelectionPage.getNextPage(Wiz ardSelectionPage
..java:96)
at
org.eclipse.ui.internal.dialogs.WorkbenchWizardSelectionPage .getNextPage(Wor
kbenchWizardSelectionPage.java:82)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:674)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:300)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:506)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:668 )
at org.eclipse.jface.window.Window.open(Window.java:648)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction .java:111)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:915)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionI
tem.java:866)
at
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContribu
tionItem.java:785)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Caused by: java.lang.NoClassDefFoundError:
org/eclipse/core/internal/indexing/ObjectStoreException
at
org.eclipse.core.internal.properties.IndexedStoreWrapper.ope n(IndexedStoreWr
apper.java:37)
at
org.eclipse.core.internal.properties.IndexedStoreWrapper.cre ate(IndexedStore
Wrapper.java:95)
at
org.eclipse.core.internal.properties.IndexedStoreWrapper.get Store(IndexedSto
reWrapper.java:165)
at
org.eclipse.core.internal.properties.IndexedStoreWrapper.get Index(IndexedSto
reWrapper.java:121)
at
org.eclipse.core.internal.properties.IndexedStoreWrapper.get Cursor(IndexedSt
oreWrapper.java:171)
at
org.eclipse.core.internal.properties.PropertyStore.recordsMa tching(PropertyS
tore.java:326)
at
org.eclipse.core.internal.properties.PropertyStore.get(Prope rtyStore.java:17
9)
at
org.eclipse.core.internal.properties.PropertyManager.getProp erty(PropertyMan
ager.java:154)
at
org.eclipse.core.internal.resources.Resource.getPersistentPr operty(Resource.
java:937)
at
org.eclipse.jdt.internal.core.JavaModelManager.loadVariables AndContainers(Ja
vaModelManager.java:1359)
at org.eclipse.jdt.core.JavaCore.start(JavaCore.java:3638)
at
xtImpl.java:958)
at
... 83 more
Root exception:
at
apper.java:37)
at
Wrapper.java:95)
at
reWrapper.java:165)
at
reWrapper.java:121)
at
at
tore.java:326)
at
9)
at
ager.java:154)
at
java:937)
at
at
xtImpl.java:958)
at
at
xtImpl.java:937)
at
ava:421)
at
..java:293)
at
assLoader.java:110)
at
oader.java:371)
at
der.java:336)
at
leLoader.java:914)
at
..java:399)
at
at
at
at
r.java:328)
at
r.java:47)
at
xtImpl.java:958)
at
at
xtImpl.java:937)
at
ava:421)
at
..java:293)
at
assLoader.java:110)
at
oader.java:371)
at
..java:402)
at
at
..java:307)
at
a:336)
at
ndle.java:1313)
at
at
at
at
:193)
at
at
Page.java:740)
at
e.java:133)
at
:615)
at
e.java:114)
at
dNode.java:112)
at
..java:96)
at
at
at
at
tem.java:866)
at
tionItem.java:785)
at
at
java:335)
at
at
!ENTRY org.eclipse.osgi Aug 08, 2004 22:53:45.51
org.eclipse.jdt.ui (16).
!STACK 0
org.eclipse.core.internal.compatibility.PluginActivator.star t() of bundle
org.eclipse.jdt.ui.
at
at
xtImpl.java:937)
at
ava:421)
at
..java:293)
at
assLoader.java:110)
at
oader.java:371)
at
..java:402)
at
at
..java:307)
at
a:336)
at
ndle.java:1313)
at
at
at
at
:193)
at
at
Page.java:740)
at
e.java:133)
at
:615)
at
e.java:114)
at
dNode.java:112)
at
..java:96)
at
at
at
at
tem.java:866)
at
tionItem.java:785)
at
at
java:335)
at
at
org/eclipse/jdt/core/IBufferFactory
at
at
at
r.java:328)
at
r.java:47)
at
xtImpl.java:958)
at
... 61 more
Root exception:
java.lang.NoClassDefFoundError: org/eclipse/jdt/core/IBufferFactory
at
at
at
r.java:328)
at
r.java:47)
at
xtImpl.java:958)
at
at
xtImpl.java:937)
at
ava:421)
at
..java:293)
at
assLoader.java:110)
at
oader.java:371)
at
..java:402)
at
at
..java:307)
at
a:336)
at
ndle.java:1313)
at
at
at
at
:193)
at
at
Page.java:740)
at
e.java:133)
at
:615)
at
e.java:114)
at
dNode.java:112)
at
..java:96)
at
at
at
at
tem.java:866)
at
tionItem.java:785)
at
at
java:335)
at
at
!ENTRY org.eclipse.core.runtime 4 1 Aug 08, 2004 22:53:45.51
!MESSAGE Plug-in org.eclipse.jdt.ui was unable to load class
org.eclipse.jdt.internal.ui.wizards.JavaProjectWizard.
!STACK 0
java.lang.ClassNotFoundException:
at
..java:404)
at
at
..java:307)
at
a:336)
at
ndle.java:1313)
at
at
at
at
:193)
at
at
Page.java:740)
at
e.java:133)
at
:615)
at
e.java:114)
at
dNode.java:112)
at
..java:96)
at
at
at
at
tem.java:866)
at
tionItem.java:785)
at
at
java:335)
at
at
!ENTRY org.eclipse.ui.ide 4 4 Aug 08, 2004 23:23:30.298
!MESSAGE Problems saving workspace
!ENTRY org.eclipse.ui.ide 4 1 Aug 08, 2004 23:23:30.318
!MESSAGE Problems occurred while trying to save the state of the workbench.
!SUBENTRY 1 org.eclipse.ui.ide 4 1 Aug 08, 2004 23:23:30.318
!MESSAGE Internal Error
!STACK 0
at
apper.java:37)
at
Wrapper.java:95)
at
reWrapper.java:165)
at
reWrapper.java:121)
at
at
org.eclipse.core.internal.localstore.HistoryStore.clean(Hist oryStore.java:25
0)
at
org.eclipse.core.internal.resources.SaveManager.save(SaveMan ager.java:1346)
at org.eclipse.core.internal.resources.Workspace.save(Workspace .java:1707)
at
org.eclipse.ui.internal.ide.IDEWorkbenchAdvisor$5.run(IDEWor kbenchAdvisor.ja
va:468)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext
..java:101)
!SESSION Aug 08, 2004
23:24:12.248 ---------------------------------------------
eclipse.buildId=I200406251208
java.version=1.4.2_04
!ENTRY org.eclipse.osgi Aug 08, 2004 23:24:12.258
!STACK 0
at
at
xtImpl.java:937)
at
ava:421)
at
..java:293)
at
assLoader.java:110)
at
oader.java:371)
at
der.java:336)
at
leLoader.java:914)
at
..java:399)
at
at
at
at
r.java:328)
at
r.java:47)
at
xtImpl.java:958)
at
at
xtImpl.java:937)
at
ava:421)
at
..java:293)
at
assLoader.java:110)
at
oader.java:371)
at
..java:402)
at
at
..java:307)
at
a:336)
at
ndle.java:1313)
at
at
at
at
:193)
at
at
Page.java:740)
at
e.java:133)
at
:615)
at
e.java:114)
at
dNode.java:112)
at
..java:96)
at
at
at
at
tem.java:866)
at
tionItem.java:785)
at
at
java:335)
at
at
at
apper.java:37)
at
Wrapper.java:95)
at
reWrapper.java:165)
at
reWrapper.java:121)
at
at
tore.java:326)
at
9)
at
ager.java:154)
at
java:937)
at
at
xtImpl.java:958)
at
... 83 more
Root exception:
at
apper.java:37)
at
Wrapper.java:95)
at
reWrapper.java:165)
at
reWrapper.java:121)
at
at
tore.java:326)
at
9)
at
ager.java:154)
at
java:937)
at
at
xtImpl.java:958)
at
at
xtImpl.java:937)
at
ava:421)
at
..java:293)
at
assLoader.java:110)
at
oader.java:371)
at
der.java:336)
at
leLoader.java:914)
at
..java:399)
at
at
at
at
r.java:328)
at
r.java:47)
at
xtImpl.java:958)
at
at
xtImpl.java:937)
at
ava:421)
at
..java:293)
at
assLoader.java:110)
at
oader.java:371)
at
..java:402)
at
at
..java:307)
at
a:336)
at
ndle.java:1313)
at
at
at
at
:193)
at
at
Page.java:740)
at
e.java:133)
at
:615)
at
e.java:114)
at
dNode.java:112)
at
..java:96)
at
at
at
at
tem.java:866)
at
tionItem.java:785)
at
at
java:335)
at
at
!ENTRY org.eclipse.osgi Aug 08, 2004 23:24:12.268
!STACK 0
org.eclipse.jdt.ui.
at
at
xtImpl.java:937)
at
ava:421)
at
..java:293)
at
assLoader.java:110)
at
oader.java:371)
at
..java:402)
at
at
..java:307)
at
a:336)
at
ndle.java:1313)
at
at
at
at
:193)
at
at
Page.java:740)
at
e.java:13
Re: Eclipse 3.0 Problem Opening Wizard [message #266007 is a reply to message #266003] |
Mon, 09 August 2004 04:00 |
I had an older eclipse (2.1) on my machine, but I renamed the directory
before installing the new eclipse. 2.1 has no problem creating a new Java
project. Just now I installed 3.0 again to another directory and got the
same errors. Is there any system info stored outside the install directory
(e.g., in registry)? Does the version of JDK installed (I use 1.4.2) affect
Eclipse? I installed from eclipse-SDK-3.0-win32.zip. Is there another
version with more files?
Mark
Mark
"Chris Laffra" <Chris_Laffra@ca.ibm.com> wrote in message
news:cf6rvo$jjg$1@eclipse.org...
> Is this a brand new Eclipse 3.0 on a new workspace?
> Sounds like you are loading a broken workspace, or something
> went wrong during download/install. I would reinstall and try again.
> Chris
> news:cf6qvi$ikc$1@eclipse.org...
> > error log info:
Re: Eclipse 3.0 Problem Opening Wizard [message #266367 is a reply to message #266007] |
Wed, 11 August 2004 03:23 |
Just in case anyone else has a similar problem: I solved the problem by
reinstalling Eclipse 3.0 from a newer build (maintenance build M20040805).
Chris: Thanks for trying to assist me.
Mark
news:cf6sq7$kcb$1@eclipse.org...
directory
affect
> Mark
> Mark
> > Chris
exported
> > > error log info:
FUDForum. Page generated in 0.03803 seconds
