Home » Eclipse Projects » Virgo » Update Virgo with org.eclipse.osgi_3.9.1
Update Virgo with org.eclipse.osgi_3.9.1 [message #1472720] Fri, 14 November 2014 03:37 Go to next message
Laurent Delamare is currently offline Laurent DelamareFriend
I noticed that Virgo 3.6.3 is still using the old org.eclipse.osgi_3.8.2.v20130124-134944.jar.
Is it possible to use org.eclipse.osgi_3.9.1.v20130814-1242.jar instead?
The reason is that 3.9.1 fixes an Equinox bug that affect bundle deployment and that I filed last year (ConcurrentModificationException in org.eclipse.osgi.internal.resolver.StateWriter.writeList, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=411718)
What is the process for updating the org.eclipse.osgi component in Virgo?
Thanks.
Re: Update Virgo with org.eclipse.osgi_3.9.1 [message #1473050 is a reply to message #1472720] Fri, 14 November 2014 09:48 Go to previous messageGo to next message
Florian Waibel is currently offline Florian WaibelFriend
In the long run we want to Support generic container based Equinox implementation (Bug 404390).
Tom Watson from the Equinox team offered a possible short term alternative which might have less impact than updating to 3.9.1 or newer:
[quote]
Also having Virgo updated to use one of the other non-deprecated writeState methods would fix the issue. [1]
[\quote]
If you solely care about the Bug you mentioned I suggest you open a bug to replace the deprecated method call(s) in Virgo to work around the
Equinox bug.
[1] http://dev.eclipse.org/mhonarc/lists/equinox-dev/msg07575.html
[Updated on: Fri, 14 November 2014 09:49]
Report message to a moderator
Re: Update Virgo with org.eclipse.osgi_3.9.1 [message #1473455 is a reply to message #1473050] Fri, 14 November 2014 16:48 Go to previous message
OK, thanks for the quick reply. I will file a bug.
Previous Topic:Virgo, Java 8, Blueprint/Spring 4.x, Tooling
Next Topic:how to update logback version in virgo?
Current Time: Sun Jun 20 11:04:24 GMT 2021
Powered by FUDForum. Page generated in 0.02138 seconds
