Home » Newcomers » Newcomers » Trying to Install New Software, Eclipse is asking for a password(Password Request on New Software)
Re: Trying to Install New Software, Eclipse is asking for a password [message #1472343 is a reply to message #1472298] |
Thu, 13 November 2014 20:10 |
David Williams Messages: 722 Registered: July 2009 |
<html>
<head>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type">
</head>
<div class="moz-cite-prefix">On 11/13/2014 02:24 PM, Dave Dernberger
wrote:<br>
</div>
<blockquote cite="mid:m430hv$fek$1@xxxxxxxxe.org" type="cite">
<pre wrap="">I have attached the password box I am getting. I have compared another user with my set up and have noticed I do not have as many Eclipse Modeling Project plugins as she does. I am not sure if this is because Eclipse is not loading completely because I cannot get past this password.
If i do cancel out the password box it loads something and then provides this error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Activiti Eclipse BPMN 2.0 Designer 5.12.0 (org.activiti.designer.feature.feature.group 5.12.0)
Missing requirement: Activiti Eclipse BPMN 2.0 Designer 5.12.0 (org.activiti.designer.feature.feature.group 5.12.0) requires 'org.eclipse.emf 2.6.0' but it could not be found
</pre>
</blockquote>
<font face="DejaVu Sans Mono">You never did say if you are behind a
proxy. Even one that normally does not require a userid/password.
<br>
<br>
Part of the reason I ask is because of bug <br>
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=422665">https://bugs.eclipse.org/bugs/show_bug.cgi?id=422665</a>, <br>
where Eclipse/p2/ecf "thinks" it needs to authenticate the proxy
when it does not. And this occurs on Windows only, as far as I
know, so assume you are on Windows? And what version of Eclipse
does Activiti say it works with? "Luna" (Eclipse 4.4?) If
something prior to that, then this would not be the bug you are
hitting. <br>
<br>
A good way to test this, if you haven't already, it to install a
"plain" Eclipse SDK 4.4.1 (so all the other software is removed
from the equation) such as from <br>
<br>
<a class="moz-txt-link-freetext" href="http://download.eclipse.org/eclipse/downloads/drops4/R-4.4.1-201409250400/#EclipseSDK">http://download.eclipse.org/eclipse/downloads/drops4/R-4.4.1-201409250400/#EclipseSDK</a><br>
(getting appropriate 32 or 64 bit, based on your machine and your
VM). <br>
<br>
And then, under help, select "install new software", pick the
repository for .../releases/Luna <br>
and try to install something from there ... Eclipse Git, XML
Editor, or something small :) <br>
<br>
If you do get the prompt then, I'd say you are running into bug </font><font
face="DejaVu Sans Mono"><font face="DejaVu Sans Mono">422665</font>
and you are "going through a proxy". <br>
If you do not get the prompt, then I think you'll have to ask
Activiti what the best course of action is. <br>
(Well, or try some of the work arounds, in bug 422665, if you have
the patience for it. :) <br>
<br>
Good luck, <br>
<br>
<br>
<br>
<br>
<br>
<br>
</font>
</body>
</html>
Re: Trying to Install New Software, Eclipse is asking for a password [message #1472366 is a reply to message #1472348] |
Thu, 13 November 2014 20:40 |
On 11/13/2014 03:18 PM, Denis Roy wrote:
> David Williams wrote on Thu, 13 November 2014 15:10
> David, your response was garbled, but I was able to pull out the above
> question, which is indeed a good question.
We'll see if this one looks any better. I'll tell it to send in "plain
text".
(I use a news reader that handles the HTML fine, and I'd think the forum
would? But, maybe the "translation" from one to the other does not?)
password.
not be found.
You never did say if you are behind a proxy. Even one that normally does
https://bugs.eclipse.org/bugs/show_bug.cgi?id=422665,
where Eclipse/p2/ecf "thinks" it needs to authenticate the proxy when it
does not. And this occurs on Windows only, as far as I know, so assume
you are on Windows? And what version of Eclipse does Activiti say it
works with? "Luna" (Eclipse 4.4?) If something prior to that, then this
would not be the bug you are hitting.
A good way to test this, if you haven't already, it to install a "plain"
Eclipse SDK 4.4.1 (so all the other software is removed from the
(getting appropriate 32 or 64 bit, based on your machine and your VM).
And then, under help, select "install new software", pick the repository
and try to install something from there ... Eclipse Git, XML Editor, or
something small :)
If you do get the prompt then, I'd say you are running into bug 422665
If you do not get the prompt, then I think you'll have to ask Activiti
(Well, or try some of the work arounds, in bug 422665, if you have the
patience for it. :)
Good luck,
Current Time: Sat Apr 20 00:02:06 GMT 2024
Powered by FUDForum. Page generated in 0.09069 seconds
