Problem with ?parseDate function [message #1470521] |
Wed, 12 November 2014 12:04 |
Dominik Gabriel Messages: 113 Registered: June 2013 |
Hello there,
i hava a problem with the ?parseDate function. In my case i just want to check if the timestamp of a generated file i correct. The AUT is able to show the timestamp in different timezones.
So i tried to use a case with a dataset to check if the different timezones are calculated correct.
So if i run this testcase locally it works without any problems. but if i run it with jenkins, the case passes the first two sets of data and with the third set i got this error: "Incorrect Function argument value."
I also tried to run the test locally on the slave that jenkins is using. i didn't have any problems that way...
Maybe someone have an idea.
FYI:
i've got this in console:
!!Error occurred !!
parsing failed, reason: Unable to parse the date: 2014-11-13 15:17 CET
Sincerely
Dominik
[Updated on: Thu, 13 November 2014 14:21] Report message to a moderator
Re: Problem with ?parseDate function [message #1476555 is a reply to message #1473271] |
Mon, 17 November 2014 06:36 |
that's my problem i can't see any difference in the date. i get it from a table with the store value (at mouse position) step. when i run the test from ITE it works fine when i run the test with testexec.exe the error occurs.
i can also reproduce the problem without jenkins, running testexec with the parameters from cmd.exe
[Updated on: Mon, 17 November 2014 06:39] Report message to a moderator
FUDForum. Page generated in 0.04546 seconds
