Re: How to disable default validation marking in EMFForms-generated controls? [message #1471655 is a reply to message #1470361] |
Thu, 13 November 2014 08:44 |
Jonas Helming Messages: 699 Registered: July 2009 |
you could remove the validation service form the view context in this
case. Setting the validation color should also work, though. Can you
report that as a BR please?
Best regards
Jonas
Am 12.11.2014 10:22, schrieb Dmitri Pisarenko:
> Hello!
> I've created a wizard page based on EMFForms-generated controls (see
> screenshot below or, if you can't see it -
> https://www.evernote.com/shard/s35/sh/ab4fdd22-b6e8-4d46-b10f-75d26e053884/cd64d40042cba4c96dc3b9f929833841).
> By default, fields with wrong data are marked by
> 1) an exclamation mark (1 in the screenshot above) and
> 2) a red background.
> This is contrary to the way errors are marked in the normal Eclipse
> wizards. In the latter, the message is written in the top part of the
> window and marked by an error sign.
> To make my EMFForms-generated controls compliant to the Eclipse
> look-and-feel, I need to
> a) disable the display of the red exclamation mark and
> b) disable changing the background of a control to red.
> How can I do it?
> I tried to set the "Error Color HEX" to white in the view template, but
> this didn't change anything.
> (click
> https://www.evernote.com/shard/s35/sh/df8407e5-de84-4cb7-85c2-302a6fc6fbd7/0874dabb64dfda81cb390a4ceb9ae52a,
> if you don't see the image)
> Thanks in advance
> Dmitri
FUDForum. Page generated in 0.02691 seconds
