Re: [EMF Client] running e3 demo with CDO repository [message #1563751 is a reply to message #1560395] |
Wed, 14 January 2015 11:28 |
Am 12.01.2015 um 16:21 schrieb ModelGeek Mising name:
> thanks!
> I am able to have CDO provider. If i try to select tcp provider and give host as localhost and port as 2036 and name
> as repo1 then when i try to open repo1 i get the following execption
> org.eclipse.net4j.signal.RemoteException: org.eclipse.emf.cdo.server.RepositoryNotFoundException: Repository not
> found: null
That "null" at the end probably means that the CDO client (here: ECP/CDO Provider) has not sent the correct repository
name ("repo1")to the server.
I don't have the ECP sources at hand (nor do I have the time right now), but if you want to debug it, I would start by
setting a breakpoint on the client in the constructor of OpenSessionRequest.java and find out why the passed repository
name is null.
Cheers
/Eike
http://www.esc-net.de
> at
> org.eclipse.emf.cdo.server.internal.net4j.protocol.OpenSessionIndication.responding(OpenSessionIndication.java:120)
> at
> org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.responding(CDOServerIndicationWithMonitoring.java:170)
> at org.eclipse.net4j.signal.IndicationWithMonitoring.responding(IndicationWithMonitoring.java:93)
> at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:98)
> at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:301)
> at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:67)
> at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:66)
> at org.eclipse.net4j.signal.Signal.runSync(Signal.java:256)
> at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
> at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
> at java.lang.Thread.run(Unknown Source)
> at org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:56)
> at org.eclipse.net4j.signal.Indication.doExtendedInput(Indication.java:57)
> at org.eclipse.net4j.signal.Signal.doInput(Signal.java:331)
> at org.eclipse.net4j.signal.Indication.execute(Indication.java:51)
> any idea why i am having this exception even when Server is up and running....
> cheers
Cheers
/Eike
FUDForum. Page generated in 0.03110 seconds
