Home » Eclipse Projects » Eclipse Platform » bundleresource:// URL problem in library plugin
bundleresource:// URL problem in library plugin [message #263929] Tue, 27 July 2004 09:49 Go to next message
I am moving code from an existing 2.1 plugin into a 3.0 RCP. Everything
worked fine under 2.1.
I am now seeing a call to getClass().getResource("file.xsd") in a dependant
DLL return a URL like bundleresource://2/file.xsd. The Xerces parser does
not like this at all, it gives a SAXParseException:
bundleresource://2/page-store-labeled.xsd' is not a valid 'anyURI' value
Anyone have any advice?
Thanks!
Rich
Re: bundleresource:// URL problem in library plugin [message #263941 is a reply to message #263929] Tue, 27 July 2004 11:23 Go to previous messageGo to next message
Originally posted by: chaves.nospam.inf.ufsc.br.ok
You can ensure the URL you handle to Xerces is a Java native one by
calling:
URL nativeURL = org.eclipse.core.runtime.Platform.resolve(pluginURL);
> Thanks!
> Rich
Re: bundleresource:// URL problem in library plugin [message #264066 is a reply to message #263941] Tue, 27 July 2004 11:51 Go to previous messageGo to next message
Thanks, but I was hoping for a solution that did not involve changing the
jar (I mistakenly refered to it as a dll in the orginal post) to link to
org.eclipse code. Note that in 2.1, that was not necessary. While this
particular jar is ours, it is used by applications outside Eclipse and we
would rather not have to package Eclipse with it in those situations.
"Rafael Chaves" <chaves@nospam.inf.ufsc.br.ok> wrote in message
news:ce5s1d$rb$1@eclipse.org...
> calling:
dependant
does
> > Thanks!
> > Rich
Re: bundleresource:// URL problem in library plugin [message #264129 is a reply to message #264066] Tue, 27 July 2004 17:36 Go to previous messageGo to next message
Not of much help, but here is the corresponding PR:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=65673
Re: bundleresource:// URL problem in library plugin [message #1752194 is a reply to message #264066] Thu, 19 January 2017 10:58 Go to previous message
This issue can be avoided by simply installing eclipse in a path without spaces.
Previous Topic:New java project does not get created correctly on network share
Next Topic:Expand Section widget in Eclipse Forms
Current Time: Thu Apr 17 15:31:09 EDT 2025
Powered by FUDForum. Page generated in 0.03270 seconds
