java.lang.ExceptionInInitializerError in latest update [message #1463604] |
Thu, 06 November 2014 18:48 |
Marco Descher Messages: 197 Registered: October 2010 Location: Austria |
Since the latest update I can't start Oomph any more, the message is:
at org.eclipse.oomph.ui.OomphUIPlugin.getDialogSettings(OomphUIPlugin.java:62)
at org.eclipse.oomph.setup.ui.wizards.SetupWizard.addPages(SetupWizard.java:225)
at org.eclipse.oomph.setup.ui.wizards.SetupWizard$Installer.addPages(SetupWizard.java:482)
at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:619)
at org.eclipse.oomph.ui.OomphWizardDialog.createContents(OomphWizardDialog.java:128)
at org.eclipse.jface.window.Window.create(Window.java:435)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1101)
at org.eclipse.oomph.setup.internal.installer.InstallerDialog.create(InstallerDialog.java:124)
at org.eclipse.jface.window.Window.open(Window.java:797)
at org.eclipse.oomph.setup.internal.installer.InstallerApplication.start(InstallerApplication.java:131)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Caused by: java.lang.IllegalStateException: Workbench has not been created yet.
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:93)
at org.eclipse.oomph.ui.UIUtil.<clinit>(UIUtil.java:43)
... 22 more
I then have to force quit Oomph; System is OS X 10.9.5
[Updated on: Thu, 06 November 2014 18:49] Report message to a moderator
Re: java.lang.ExceptionInInitializerError in latest update [message #1463643 is a reply to message #1463604] |
Thu, 06 November 2014 19:40 |
Hi Marco,
I just noticed that myself the other minute. That was my fault and I
a) fixed it (test outstanding)
b) submitted http://bugs.eclipse.org/450392
Unfortunately (see that bug) you need to download and unzip the latest installer to get my fix. Sorry for the
inconvenience!!
Cheers
/Eike
http://www.esc-net.de
Am 06.11.2014 um 19:48 schrieb Marco Descher:
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> ... 22 more
Cheers
/Eike
FUDForum. Page generated in 0.03310 seconds
