Home » Modeling » EMF » Reloading Genmodel overrides URIs
Reloading Genmodel overrides URIs [message #1463436] Thu, 06 November 2014 15:01 Go to next message
Missing name Mising name is currently offline Missing name Mising nameFriend
I am referencing third-party ecore files from my ecore file via platform plugin URIs. This works fine.
However, everytime I reload my genmodel it changes the URIs to resource URIs ("../.." instead of "platform:/plugin" in the text file).
This breaks everything, e.g., GMF cannot work with that ecore anymore. So I have to change all URIs back each time after I reloaded the genmodel.
This is really annoying. Does anybody else have this problem? Or is it a wrong configuration of my genmodel?
Thanks for your help!
Re: Reloading Genmodel overrides URIs [message #1464305 is a reply to message #1463436] Fri, 07 November 2014 12:00 Go to previous message
Perhaps GMF is failing to keep up with the latest design changes. In
particular, perhaps they're not calling
resourceSet.getURIConverter().getURIMap().putAll(EcorePlugin.computePlatformURIMap(true));
but rather using the older deprecated call (with no arguments) which
passes (false) to the newer method. This was changed back in EMF 2.9
so is not a recent change...
On 06/11/2014 4:01 PM, Missing name Mising name wrote:
> file). This breaks everything, e.g., GMF cannot work with that ecore
> the genmodel.
Previous Topic:[CDO] Stop/Close a running CDO server does not work
Next Topic:EMF Edit ItemProvider getText method always returns a default string?
Current Time: Sat Jan 18 08:24:06 GMT 2020
Powered by FUDForum. Page generated in 0.02024 seconds
