Home » Eclipse Projects » Sirius » [Feature] Navigate between model explorer & diagram elements
[Feature] Navigate between model explorer & diagram elements [message #1463254] Thu, 06 November 2014 11:11 Go to next message
Johan Van Noten is currently offline Johan Van NotenFriend
Member
Scenario:
Most model based tools allow some navigation between model elements and their corresponding representation on diagrams. We only partially find this feature in a Sirius based editor.
Works:
* If I click on a model element in the model explorer, that model element is high-lighted in the current diagram or table (if the object is backing a line).
Desired feature (s):
* Can this be bidirectional? Clicking in the diagram/table could also highlight the element in the model explorer. Currently, Always the representation element is highlighted afais.
* Is there some "find in representations"? This would work similar to the normal Eclipse search: a list of occurrences in representations, clicking on the occurrence navigates to the diagram and highlights the object in the diagram.
* Can it also work for table columns?
Re: [Feature] Navigate between model explorer & diagram elements [message #1463481 is a reply to message #1463254] Thu, 06 November 2014 15:58 Go to previous messageGo to next message
Pierre-Charles David is currently offline Pierre-Charles DavidFriend
Hi.
Thanks for the feedback; could you open a Bugzilla issue [1] for this?
Feature requests are tracked and discusses there, not in the forum.
Thanks in advance.
[1] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Sirius
Le 06/11/2014 12:11, Johan Van Noten a écrit :
> Scenario:
> Works:
> is backing a line).
Pierre-Charles David - Obeo
Need professional services for Sirius?
Re: [Feature] Navigate between model explorer & diagram elements [message #1463493 is a reply to message #1463254] Thu, 06 November 2014 16:11 Go to previous message
Maxime Porhel is currently offline Maxime PorhelFriend
> Scenario:
> Works:
> is backing a line).
Did you try CTRL+O (cmd+O on mac) on a diagram ? This opens a quick
search popup which presents you the elements displayed in a tree, then
the selected elements are highlighted/selected in the diagram
The corresponding feature does not exist in the Table editors yet,
please see Pierre-Charles's answer which indicates the bugzilla adress.
Maxime - Obeo
Maxime Porhel - Obeo
Previous Topic:Create edge End Label from a target element property
Next Topic:[Feature] Draw table cells also for "empty" cells
Current Time: Sun Jul 25 13:57:58 GMT 2021
Powered by FUDForum. Page generated in 0.01715 seconds
