Persist Getter/Setter Insertion Point [message #263107] |
Wed, 13 August 2008 21:35 |
Originally posted by: nowhere.a.com
I just installed 3.4
The Generate Getter and Setter Insertion Point does not persist between
calls. I prefer "Last Member", but now this choice always changes.
Wojtek :-)
Re: Persist Getter/Setter Insertion Point [message #263146 is a reply to message #263132] |
Thu, 14 August 2008 14:42 |
> This works for me i.e. it keeps my previous settings.
And in previous versions it did that for me. Now it always wants to put
it right after whichever field/method I happen to rest the cursor on.
So I constantly need to scroll the list to the top entry - 1 to get
Last Member.
I could not find any property for this, so it must be built in.
Actully I use a fair number of inner/nested classes. I wish there was
an option to place the get/set as the last member BEFORE a class
declaration.
Wojtek :-)
Re: Persist Getter/Setter Insertion Point [message #263157 is a reply to message #263155] |
Thu, 14 August 2008 17:59 |
>> And in previous versions it did that for me. Now it always wants to put it
>> So I constantly need to scroll the list to the top entry - 1 to get Last
>> Member.
> Please file a bug with steps to reproduce against JDT UI.
Not sure I could. From your comments it works, yet mine does not. That
would make it an installation specific bug. I did have some problems
getting Eclipse EE installed and configured (my comments in
eclipse.webtools). So to repoduce this I would guess you would need to
start with my previous environment, and go through the steps I took.
I don't even think I can remember them all.
It sounds like I have a slightly corrupted properties file somewhere
which is not "taking" the setting.
Wojtek :-)
Re: Persist Getter/Setter Insertion Point [message #263377 is a reply to message #263157] |
Mon, 18 August 2008 21:44 |
>>> Member.
I'm having the same problem, did you ever come up with a fix? Or a bug
report?
Thanks!
Re: Persist Getter/Setter Insertion Point [message #263419 is a reply to message #263377] |
Tue, 19 August 2008 22:35 |
>>>> Member.
> report?
I need to switch my email over to where I am now, so I will create a
bug tommorrow.
However I also have another problem in that the column widths of the
Problem view are not being persisted. This may be related. How are your
column widths?
Wojtek :-)
Re: Persist Getter/Setter Insertion Point [message #263421 is a reply to message #263146] |
Tue, 19 August 2008 22:48 |
Wojtek wrote :
> Actully I use a fair number of inner/nested classes. I wish there was an
> option to place the get/set as the last member BEFORE a class declaration.
If I hover over a new field in a class (one which I just typed in), I
get a quick fix "create getter and setter". This getter/setter creator
by default wants to place the new methods after the last method, yet
before the class.
I opened an enhancement bug for this behaviour:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=160344
Yet the quick fix has that already done.
Wojtek :-)
Re: Persist Getter/Setter Insertion Point [message #263463 is a reply to message #263389] |
Wed, 20 August 2008 15:28 |
>>>>>>> between calls. I prefer "Last Member", but now this choice always
>>>>>>> changes.
>>>>> Member.
>> report?
> No bug and hence no fix.
Bug 244716
Wojtek :-)
FUDForum. Page generated in 0.09311 seconds
