Home » Modeling » TMF (Xtext) » Run mwe2 workflow using maven and fornax-oaw-m2-plugin("module not found" when .mwe2 is in different project)
Run mwe2 workflow using maven and fornax-oaw-m2-plugin [message #1462301] Wed, 05 November 2014 12:34 Go to next message
Steffen Härtlein is currently offline Steffen HärtleinFriend
Hi all,
I'm relatively new to DSLs and Xtext and so I hope that I can explain my problem correctly:
I have two projects that are relevant for the problem:
- One that contains the DSL called "glue" and a "GenerateGlue.mwe2" workflow.
- Another project (let's call it "foo") that contains a ".glue" file to generate java code with
I heard that you can use the fornax-oaw-m2-plugin to realize this code generation with maven instead of starting the workflow in eclipse.
So I use the plugin in the "foo" project but I am trying to run the workflow within the "glue" project. In the configuration of the fornax-plugin I wrote:
<configuration>
    <workflowDescriptor>path.to.glue.workflow.GenerateGlue.mwe2</workflowDescriptor>
</configuration>
And also I added the "glue" project as a dependency to the project.
Now that I try to run maven I get the error:
"ERROR Mwe2Launcher - Couldn't find module path.to.glue.workflow.GenerateGlue.mwe2"
Any idea what I am doing wrong? Is it even possible to run a workflow that is in another project?
[Updated on: Wed, 05 November 2014 13:06]
Report message to a moderator
Re: Run mwe2 workflow using maven and fornax-oaw-m2-plugin [message #1462347 is a reply to message #1462301] Wed, 05 November 2014 13:33 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
If you use Xtext 2.7.x, you may want to use a more straight forward
approach to generate the language. See the docs at
https://www.eclipse.org/Xtext/documentation.html
Best,
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Go visit: http://xtext.itemis.com
Re: Run mwe2 workflow using maven and fornax-oaw-m2-plugin [message #1462352 is a reply to message #1462347] Wed, 05 November 2014 13:39 Go to previous messageGo to next message
I am using Xtext 2.6.2... so not 2.7.x
Re: Run mwe2 workflow using maven and fornax-oaw-m2-plugin [message #1462612 is a reply to message #1462352] Wed, 05 November 2014 19:30 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi did you have a look at https://github.com/cdietrich/xtext-maven-example
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: Run mwe2 workflow using maven and fornax-oaw-m2-plugin [message #1463083 is a reply to message #1462301] Thu, 06 November 2014 07:34 Go to previous messageGo to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
On 05/11/2014 14:02, Steffen Härtlein wrote:
> Hi all,
> problem correctly:
> workflow.
> <configuration>
> </configuration>
> that is an another project?
that should be a path, so instead of
path.to.glue.workflow.GenerateGlue.mwe2 it should be
path/to/glue/workflow/GenerateGlue.mwe2
or was it just a typo in your message?
is the mwe2 file in the foo project or in the glue project?
cheers
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Run mwe2 workflow using maven and fornax-oaw-m2-plugin [message #1463123 is a reply to message #1463083] Thu, 06 November 2014 08:33 Go to previous messageGo to next message
@Christian Dietrich:
Yes, I did. In that case it works because the mwe2 file is in the same project
No, that was not a typo. When I change the path to your solution it tries to find the file at the path
<basedir of my project>/path/to/glue/workflow/GenerateGlue.mwe2
That path does not exist because the mwe2 file is in the other project, the glue project. Can I access the file inside the dependency jar via the classpath somehow?
Re: Run mwe2 workflow using maven and fornax-oaw-m2-plugin [message #1463142 is a reply to message #1463123] Thu, 06 November 2014 08:57 Go to previous messageGo to next message
this should work if you refer it by name and not by path
<workflowDescriptor>the.full.qualified.name.of.my.WorkflowModule</workflowDescriptor>
module the.full.qualified.name.of.my.WorkflowModule
Workflow {
Re: Run mwe2 workflow using maven and fornax-oaw-m2-plugin [message #1463177 is a reply to message #1463142] Thu, 06 November 2014 09:37 Go to previous message
That worked for me! Thanks!
I just had to change "path.to.glue.workflow.GenerateGlue.mwe2" to
"path.to.glue.workflow.GenerateGlue", because that was the module name in the mwe2 file.
Thank you all for your responses!
Previous Topic:How to reduce lookahead, by adding leading keywords in grammar or k parameter in *mwe2 file?
Next Topic:Parser jumps from rule to rule erratically
Current Time: Tue Apr 16 15:13:28 GMT 2024
Powered by FUDForum. Page generated in 1.17772 seconds
