Home » Modeling » EMF » How to enforce an EReference to be initialized on creation of container
How to enforce an EReference to be initialized on creation of container [message #1461207] Tue, 04 November 2014 10:13 Go to next message
Thorsten Schlathölter is currently offline Thorsten SchlathölterFriend
I have a question regarding initialization of an EReference which is modeled as a containment to is parent object. Is it possible to have this EReference be initialized upon creation of the container? So that I can omit null checks when accessing the object?
For example when I have a Document with MetaData. I would like to achieve that document.getMetaData() is never null.
Thx.
Thorsten
Re: How to enforce an EReference to be initialized on creation of container [message #1461259 is a reply to message #1461207] Tue, 04 November 2014 11:29 Go to previous messageGo to next message
Erdal Karaca is currently offline Erdal KaracaFriend
You could provide your own service API to create your business objects, for example:
IDocumentService#createDocument()
The impl of that method would call the generated model Factory and "decorate" the object as needed...
Thorsten Schlathölter wrote on Tue, 04 November 2014 11:13
Thx.
Thorsten
Re: How to enforce an EReference to be initialized on creation of container [message #1461267 is a reply to message #1461207] Tue, 04 November 2014 11:35 Go to previous messageGo to next message
Thorsten,
Comments below.
On 04/11/2014 11:13 AM, Thorsten Schlathölter wrote:
That depends a bit of when/where you want to do that. Certainly you
need to be very cautious about what you do directly in the model code so
as not to break things like deserialization and copying...
So it's not generally a good idea to initialize an object in the
generated constructor, whoever tempting that may be.
If the purpose is to make the user's life easier, it's always reasonable
to create more fully initialized instances in the item providers, e.g.,
org.eclipse.emf.ecore.provider.EGenericTypeItemProvider.collectNewChildDescriptors(Collection<Object>,
Object)
If the issue is more one how you write the logic programmatically, for a
case like that, you might want to provide convenience operations for
that purpose...
You might have a method document.getOrCreateMetaData() (not the nicest
name, but you can be creative) that ensures null is never returned...
> Thx.
> Thorsten
Ed Merks
Re: How to enforce an EReference to be initialized on creation of container [message #1461268 is a reply to message #1461207] Tue, 04 November 2014 11:39 Go to previous messageGo to next message
Felix Dorner is currently offline Felix DornerFriend
On 04/11/2014 11:13, Thorsten Schlathölter wrote:
Maybe you're served fine by using a customized DocumentItemProvider.
Just look in the createNewChildDescriptor. There, the Document object is
instanciated, but nothing prevents you from also instantiating a
Metadata object and establishing the reference Doc->Metadata here. When
the user then clicks the Add->Document, the document already has its
Metadata child.
Re: How to enforce an EReference to be initialized on creation of container [message #1461273 is a reply to message #1461268] Tue, 04 November 2014 11:42 Go to previous message
>> Hi,
Uhm , that would be the ItemProvider for elements that can contain
Documents, not the DocumentItemProvider itself. Sorry for confusion.
Previous Topic:EclipseCon NA 2015: Call for Papers
Next Topic:Help me to fix reset list of command execution
Current Time: Wed Sep 23 12:52:38 GMT 2020
Powered by FUDForum. Page generated in 0.01571 seconds
