Home » Newcomers » Newcomers » How to disable a plugin (subclipse) in Eclipse v 3.4?
How to disable a plugin (subclipse) in Eclipse v 3.4? [message #262449] |
Mon, 04 August 2008 13:17 |
Originally posted by: www.nospam.net
The plugin subclipse is included and activated by default. I don't want
it. I cannot find out how to disable it.
I found something on the web(see the link below), which is consistent
with what I remembered, but in version 3.4, next to Help -> Software
Updates is "...", not an arrow. When I click "Software Updates", it
brings "Software Updates and Add-ons". There is no "Manage Configuratin"
available.
http://easyeclipse.org/site/help/manage-uninstall.html
Thank you very much.
Re: How to disable a plugin (subclipse) in Eclipse v 3.4? [message #262453 is a reply to message #262449] |
Mon, 04 August 2008 13:35 |
Originally posted by: eclipse-news.rizzoweb.com
www wrote:
> available.
If you look at the Software Updates GUI, you should notice that there is
an "Installed Software" tab, and on that, an "Uninstall" button. Select
the plugin(s) you want to remove and use that button.
Hope this helps,
Eric
Re: How to disable a plugin (subclipse) in Eclipse v 3.4? [message #262456 is a reply to message #262453] |
Mon, 04 August 2008 13:54 |
> Hope this helps,
> Eric
I followed your instructions. However, under the tab "Installed
Software", no matter which one I highlighted, the button "Uninstall.."
is always grayed out.
I am using Eclipse installed in Linux server by the superuser. Every
developer use it. We don't have individual Eclipse installation.
Previously, using version v3.2 and v3.3, I can enable/disable any
plugins by myself. I can also download any plugin just for myself to
use, not affecting other developers.
I don't understand why the "Uninstall.." button is always grayed.
Re: How to disable a plugin (subclipse) in Eclipse v 3.4? [message #262458 is a reply to message #262456] |
Mon, 04 August 2008 14:15 |
It's disabled because you don't have write permissions to modify the
installation (superuser install).
You'll have to talk to your superuser about making subclipse optional by
installing it into a different directory, so that it can be linked
rather than installed into the base.
As to the concept of "disabling" plugins, AFAIK that concept doesn't
exist in Eclipse 3.4 (unless you tell it to use the old Update Manager
functionality instead of the new p2 Install Manager / Update UI).
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: How to disable a plugin (subclipse) in Eclipse v 3.4? [message #1726260 is a reply to message #262458] |
Thu, 10 March 2016 18:57 |
Nuno Godinho de Matos Messages: 34 Registered: September 2012 |
Member |
I've gotten a pre-packaged eclipse with some plugins installed, such as the sonar plugin which seems to interfere with the maven import wizard.
Trying to get rid of the sonar plugin, I've also noticed, on windows, that the uninstall option on the sonar plugin is disabled, as well as on may of the pre-bundled plugins such as easy shell and others.
Permissions, ... I would be very surprised to see that there is any lack of permissions to do anything on the eclipse installation folder.
In fact my user has taken ownership of the full folder hiearchy where eclipse is placed. This has gotten to the point where on the eclipse folder, not only my users, but all users, have full folder permissions everywhere given recursively to all the directory hierarchy: plugins, dropings, etc... you name it.
Running eclipse.exe as administrator also has no effect.
This pre bundled eclipsed shows the uninstall button disabled on every single plugin. To get rid of sonar plugin and get the import mvn project wizard, I saw no alternative than to search the dropins folder for anything named sonar, and move them out.
Any suggestions on what else might be experimented to get the uninstall button to stop being disabled on a plugin:
after > properties, > security > Advanced > change owner your user +
> propertireis > all LoggedInUSers > give Full Control
I see little else that can be done to make the eclipse folder hierarchy more permissive.
NOTE: this is on eclipse mars.
Thanks.
[Updated on: Thu, 10 March 2016 18:59] Report message to a moderator
Current Time: Tue Apr 23 12:00:54 GMT 2024
Powered by FUDForum. Page generated in 0.09373 seconds
