Home » Modeling » QVT-OML » Error while generating Diagram Editor Gen Model
Error while generating Diagram Editor Gen Model [message #1458064] Sat, 01 November 2014 01:12 Go to next message
Ersel Aker is currently offline Ersel AkerFriend
Hi I was following the mindmap GMF example, but when I try to create Diagram Editor GMF Gen Model using the GMF Dashboard. I get the following error:
Unhandled event loop exception
java.lang.NoSuchMethodError: org.eclipse.m2m.internal.qvt.oml.compiler.QVTOCompiler.createCompilerWithHistory(Lorg/eclipse/m2m/internal/qvt/oml/compiler/UnitResolver;Lorg/eclipse/emf/ecore/resource/ResourceSet;)Lorg/eclipse/m2m/internal/qvt/oml/compiler/QVTOCompiler;
	at org.eclipse.gmf.internal.xpand.util.ResourceManagerImpl.getQvtCompiler(ResourceManagerImpl.java:97)
	at org.eclipse.gmf.internal.xpand.util.ResourceManagerImpl.doLoadQvtResource(ResourceManagerImpl.java:75)
	at org.eclipse.gmf.internal.xpand.util.ResourceManagerImpl.loadQvtResourceThroughCache(ResourceManagerImpl.java:63)
	at org.eclipse.gmf.internal.xpand.util.ResourceManagerImpl.loadQvtResource(ResourceManagerImpl.java:46)
	at org.eclipse.gmf.internal.xpand.model.Scope.findExtension(Scope.java:148)
	at org.eclipse.gmf.internal.xpand.model.ExecutionContextImpl.getImportedModules(ExecutionContextImpl.java:293)
	at org.eclipse.gmf.internal.xpand.model.ExecutionContextImpl.getOCLEnvironment(ExecutionContextImpl.java:254)
	at org.eclipse.gmf.internal.xpand.ocl.TypeHelper.getTypeForName(TypeHelper.java:35)
	at org.eclipse.gmf.internal.xpand.model.ExecutionContextImpl.findDefinition(ExecutionContextImpl.java:231)
	at org.eclipse.gmf.internal.xpand.model.ExecutionContextImpl.findDefinition(ExecutionContextImpl.java:167)
	at org.eclipse.gmf.internal.xpand.XpandFacade.evaluate(XpandFacade.java:54)
	at org.eclipse.gmf.graphdef.codegen.FigureGenerator.go(FigureGenerator.java:99)
	at org.eclipse.gmf.internal.bridge.genmodel.InnerClassViewmapProducer.createViewmap(InnerClassViewmapProducer.java:128)
	at org.eclipse.gmf.internal.bridge.genmodel.InnerClassViewmapProducer.create(InnerClassViewmapProducer.java:76)
	at org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTransformer.process(DiagramGenModelTransformer.java:413)
	at org.eclipse.gmf.internal.bridge.genmodel.MappingTransformer.transform(MappingTransformer.java:31)
	at org.eclipse.gmf.internal.bridge.transform.TransformToGenModelOperation$2.process(TransformToGenModelOperation.java:435)
	at org.eclipse.gmf.internal.bridge.transform.TransformToGenModelOperation.executeTransformation(TransformToGenModelOperation.java:265)
	at org.eclipse.gmf.internal.bridge.ui.dashboard.actions.TransformMap2GenModelAction.run(TransformMap2GenModelAction.java:65)
	at org.eclipse.gmf.internal.bridge.ui.dashboard.HyperlinkFigure$1.mousePressed(HyperlinkFigure.java:63)
	at org.eclipse.draw2d.Figure.handleMousePressed(Figure.java:935)
	at org.eclipse.draw2d.SWTEventDispatcher.dispatchMousePressed(SWTEventDispatcher.java:242)
	at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDown(LightweightSystem.java:523)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:192)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4188)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1467)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1490)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1475)
	at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1279)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4031)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3658)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Session Data:
eclipse.buildId=4.4.1.M20140925-0400
java.version=1.7.0_67
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.modeling.product -keyring /Users/er/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.modeling.product -keyring /Users/er/.eclipse_keyring -showlocation
can anyone help me resolve this issue, I am using Eclipse Luna with Modeling Tools.
Re: Error while generating Diagram Editor Gen Model [message #1459443 is a reply to message #1458064] Sun, 02 November 2014 13:53 Go to previous messageGo to next message
The problem is that a redundant argument was removed from
QVTOCompiler.createCompilerWithHistory in the Luna release; from Luna M2
actually. Since QVTOCompiler is in an internal package, there is no API
compatibility prohibition in this. Code such as
that exploit internal functionality must track the internal changes.
If you are sure that you are using both Luna GMF and QVTo you should
raise a bug against GMF. As a workaround you might try the Kepler QVTo.
Since I find it difficult to understand how GMF could fail to notice the
compilation error, I suggest that you fix your installation.
Ed Willink
> following error:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> Session Data:
> java.vendor=Oracle Corporation
> Modeling Tools.
Re: Error while generating Diagram Editor Gen Model [message #1463135 is a reply to message #1458064] Thu, 06 November 2014 08:49 Go to previous messageGo to next message
Christopher Gerking is currently offline Christopher GerkingFriend
Member
Maybe you stumbled over the problem that Eclipse Modeling Tools for Luna still ships with the Kepler QVTo.
Re: Error while generating Diagram Editor Gen Model [message #1463204 is a reply to message #1463135] Thu, 06 November 2014 10:09 Go to previous messageGo to next message
On 06/11/2014 08:49, Christopher Gerking wrote:> Maybe you stumbled over
http://download.eclipse.org/releases/luna seems ok to me. It seems very
unlikely that it is wrong.
Sergey certainly updated the Luna aggregator for M6,M7,RC1,RC2,RC3,RC4.
David Williams moved the repo from milestones to luna/releases in
September presumably because the ongoing use of a milestones release was
unhelpful.
Are you suggesting that the Additional Modeling Packages is offering
Kepler? That seems much more likley it's happened more than once before
and just requires a poke to Amalgam?
Ed Willink
Re: Error while generating Diagram Editor Gen Model [message #1463324 is a reply to message #1463204] Thu, 06 November 2014 12:52 Go to previous message
Member
Ed Willink wrote on Thu, 06 November 2014 05:09
Are you suggesting that the Additional Modeling Packages is offering Kepler? That seems much more likley it's happened more than once before
Yes, the Eclipse Modeling Components Discovery dialog did so. Can't reproduce today, so must have been fixed.
Previous Topic:QVT standard library extension
Next Topic:Transform qvto file standalone
Current Time: Thu Dec 03 12:13:07 GMT 2020
Powered by FUDForum. Page generated in 0.01653 seconds
