Home » Eclipse Projects » Riena » Wrong service implementation used since 1.1.0M7
Wrong service implementation used since 1.1.0M7 [message #25856] Wed, 13 May 2009 05:41 Go to next message
Carsten Spieker is currently offline Carsten SpiekerFriend
since I switched to Riena 1.1.0M7 I have problems with my own implementation
of IPermissionStore.
I implemented IPermissionStore in my own bundle and registered it with
service.ranking=0 (since riena services are registered with
service.ranking=-100). My bundle and the bundle
org.eclipse.riena.security.simpleServices are both ACTIVE on server side.
When checking services in the OSGi Management agent I can see that the
service implementation of org.eclipse.riena.security.simpleServices is used
and not mine. Because of that my IPermissionStore implementation is not used
when checking user rights using Sentinel-class.
What can be wrong here? With 1.1.0M6 everything worked fine.
Thanks a lot!
Greetz,
Carsten
Re: Wrong service implementation used since 1.1.0M7 [message #25898 is a reply to message #25856] Wed, 13 May 2009 06:32 Go to previous messageGo to next message
This is the information shown in OSGi Management Agent:
<agent-output>
{org.eclipse.riena.security.authorizationservice.IPermission Store}={service.ranking=0,
service.id=70}
Registered by bundle: com.pa.eai.spieker.authentication_1.0.0.qualifier
[14]
No bundles using service.
{org.eclipse.riena.security.authorizationservice.IPermission Store}={service.ranking=-100,
service.id=76}
Registered by bundle: org.eclipse.riena.security.simpleservices_1.1.0.M7
[36]
Bundles using service:
org.eclipse.riena.security.services_1.1.0.M7 [34]
</agent-output>
Greetz,
Carsten
"Carsten Spieker" <carsten.spieker@d-velop.de> schrieb im Newsbeitrag
news:gudmhe$avr$1@build.eclipse.org...
> implementation of IPermissionStore.
> used and not mine. Because of that my IPermissionStore implementation is
> not used when checking user rights using Sentinel-class.
> Thanks a lot!
> Greetz,
> Carsten
Re: Wrong service implementation used since 1.1.0M7 [message #26184 is a reply to message #25898] Mon, 18 May 2009 04:52 Go to previous messageGo to next message
Does not anyone have the same problem with 1.1.0M7 or any idea?
Thanks a lot!
Carsten
news:gudpi2$6jl$1@build.eclipse.org...
> <agent-output>
> service.id=70}
> [14]
> service.id=76}
> [36]
> </agent-output>
> Greetz,
> Carsten
>> Hi,
>> Thanks a lot!
>> Greetz,
>> Carsten
Re: Wrong service implementation used since 1.1.0M7 [message #26265 is a reply to message #26184] Mon, 18 May 2009 13:35 Go to previous messageGo to next message
Christian Campo is currently offline Christian CampoFriend
Hi Carsten,
I am sorry that I am coming back to late. We are really in a little bit of stress with the Galileo Release. What you
describe sounds like a bug. Please dont hesitate and file a bug report if you find something like this. And then we will
look into the problem.
Looks very strange indeed. However the bundle org.eclipse.riena.security.simpleservices is not meant for production or a
real system. Its the intentention that you simply not deploy it and only use your own implementations of
IPermissionStore and ISessionStore and LoginModule.
cheers
christian
> Thanks a lot!
> Carsten
>> <agent-output>
>> service.id=70}
>> [14]
>> service.id=76}
>> [36]
>> </agent-output>
>> Greetz,
>> Carsten
>>> Hi,
>>> Thanks a lot!
>>> Greetz,
>>> Carsten
Re: Wrong service implementation used since 1.1.0M7 [message #26380 is a reply to message #26265] Tue, 19 May 2009 06:11 Go to previous message
Hi Christian,
I opened bug 276738.
Greetz,
Carsten
"Christian Campo" <christian.campo@compeople.de> schrieb im Newsbeitrag
news:4A116430.3000207@compeople.de...
> Hi Carsten,
> stress with the Galileo Release. What you describe sounds like a bug.
> this. And then we will look into the problem.
> use your own implementations of IPermissionStore and ISessionStore and
> LoginModule.
> cheers
> christian
>> Thanks a lot!
>> Carsten
>>> <agent-output>
>>> service.id=70}
>>> [14]
>>> service.id=76}
>>> org.eclipse.riena.security.simpleservices_1.1.0.M7 [36]
>>> </agent-output>
>>> Greetz,
>>> Carsten
>>>> Hi,
>>>> side. When checking services in the OSGi Management agent I can see
>>>> that the service implementation of
>>>> org.eclipse.riena.security.simpleServices is used and not mine. Because
>>>> of that my IPermissionStore implementation is not used when checking
>>>> Thanks a lot!
>>>> Greetz,
>>>> Carsten
Re: Wrong service implementation used since 1.1.0M7 [message #582435 is a reply to message #25856] Wed, 13 May 2009 06:32 Go to previous message
<agent-output>
service.id=70}
[14]
service.id=76}
[36]
</agent-output>
Greetz,
Carsten
> Thanks a lot!
> Greetz,
> Carsten
Re: Wrong service implementation used since 1.1.0M7 [message #582560 is a reply to message #25898] Mon, 18 May 2009 04:52 Go to previous message
Thanks a lot!
Carsten
> <agent-output>
> service.id=70}
> [14]
> service.id=76}
> [36]
> </agent-output>
> Greetz,
> Carsten
>> Hi,
>> Thanks a lot!
>> Greetz,
>> Carsten
Re: Wrong service implementation used since 1.1.0M7 [message #582584 is a reply to message #26184] Mon, 18 May 2009 13:35 Go to previous message
Hi Carsten,
cheers
christian
> Thanks a lot!
> Carsten
>> <agent-output>
>> service.id=70}
>> [14]
>> service.id=76}
>> [36]
>> </agent-output>
>> Greetz,
>> Carsten
>>> Hi,
>>> Thanks a lot!
>>> Greetz,
>>> Carsten
Re: Wrong service implementation used since 1.1.0M7 [message #582627 is a reply to message #26265] Tue, 19 May 2009 06:11 Go to previous message
Hi Christian,
Greetz,
Carsten
> Hi Carsten,
> LoginModule.
> cheers
> christian
>> Thanks a lot!
>> Carsten
>>> <agent-output>
>>> service.id=70}
>>> [14]
>>> service.id=76}
>>> </agent-output>
>>> Greetz,
>>> Carsten
>>>> Hi,
>>>> Thanks a lot!
>>>> Greetz,
>>>> Carsten
Previous Topic:where to do the remote service call
Next Topic:RAP Support
Current Time: Tue Apr 16 06:00:45 GMT 2024
Powered by FUDForum. Page generated in 0.23952 seconds
