Home » Archived » BIRT » Ellipsis support?
Ellipsis support? [message #260453] Fri, 02 November 2007 15:36 Go to next message
I am mainly using BIRT for PDF output. A problem I have is with a table
containing text that may be too large for the column. It winds up on the
next line making the row larger. Is it possible to tell BIRT to either just
truncate the text to make it fit or put an ellipsis in at the end of the
text?
Re: Ellipsis support? [message #1016889 is a reply to message #260453] Fri, 08 March 2013 00:24 Go to previous messageGo to next message
Did you ever solve this?, I'm having the same issue.
Re: Ellipsis support? [message #1017043 is a reply to message #1016889] Fri, 08 March 2013 13:07 Go to previous message
Did you select no-wrapping in the property view for the data item?
Jason
Previous Topic:Table Row span problem
Next Topic:BIRT 4.2.2 Update Site
Current Time: Fri Jun 13 10:13:06 EDT 2025
Powered by FUDForum. Page generated in 0.35881 seconds
