Home » Eclipse Projects » Hudson » How to test REST Client using Hudson
icon2.gif  How to test REST Client using Hudson [message #1453106] Sun, 26 October 2014 11:47 Go to next message
Xtreme Sony is currently offline Xtreme SonyFriend
I would like to know if I can use Hudson as a REST Client for online service?
Moreover, can I create job that takes its input from the previous job result?
Re: How to test REST Client using Hudson [message #1469688 is a reply to message #1453106] Tue, 11 November 2014 20:37 Go to previous messageGo to next message
Winston Prakash is currently offline Winston PrakashFriend
Can you explain "Online Service"? Hudson has enough REST API to create client of your own. Either you could use the classic REST Api or the API exported via the REST plugin.
Winston Prakash
Eclipse Hudson team
Re: How to test REST Client using Hudson [message #1469780 is a reply to message #1469688] Tue, 11 November 2014 22:21 Go to previous messageGo to next message
Any normal online service with GET, POST, PUT requests.
Re: How to test REST Client using Hudson [message #1469864 is a reply to message #1469780] Wed, 12 November 2014 00:04 Go to previous message
You might want to check the REST API provided by Hudson REST plugin
http://ci.hudson-ci.org/plugin/rest-plugin/api/rest.html
Winston Prakash
Eclipse Hudson team
Previous Topic:change to default port
Next Topic:"Build when Maven dependencies have been updated" uses transitive dependencies?
Current Time: Fri Oct 30 03:03:01 GMT 2020
Powered by FUDForum. Page generated in 0.01556 seconds
