Home » Archived » XML Schema Definition (XSD) » namespace prefix to URL resolution
namespace prefix to URL resolution [message #25678] |
Thu, 31 July 2003 16:50 |
Originally posted by: carman.itc.it
Dear All,
I'm trying to obtain the (simple) type definitions of "elements" within
soap encoded arrays. Here's an example of one such array declaration:
<xsd:attribute ref="soapenc:arrayType"
wsdl:arrayType="typens:CustomerReview[]"/>
Here the attribute, "arrayType" is a string, but the SOAP engine
understands that the string really contains objects of type
"typens:CustomerReview" as a single dimensional array. (Ugly way of
encoding your data, I know, but people seem to use this construction!)
My problem is, that when inspecting such an attribute, I want to resolve
the "typens:CustomerReview" (simple) type definition and view its
properties. Before calling the resolveSimpleTypeDefinition() method, I
need to find the URL which the namespace prefix "typens" represents. I had
a look in both the XSD and DOM apis and couldn't find a method to do this.
Does anybody know how to map prefixes to the URLs they represent? I'm sure
it must be really simple.
Thanks a lot,
Mark
Re: namespace prefix to URL resolution [message #25819 is a reply to message #25678] |
Thu, 31 July 2003 17:13 |
--------------1588619BC5AD3F6387D487AD
Content-Type: text/plain; charset=us-ascii
Mark,
Here's some code that given a complex type that is a soap encoding array type
will return the resolved item type (or null otherwise):
protected Object
getSOAPEncodingArrayItemType(XSDComplexTypeDefinition
xsdComplexTypeDefinition)
if
(xsdComplexTypeDefinition.getBaseTypeDefinition().getURI().e quals(SOAP_ENCODING_ARRAY))
for (Iterator attributeContents =
xsdComplexTypeDefinition.getAttributeContents().iterator();
attributeContents.hasNext(); )
XSDAttributeUse xsdAttributeUse =
(XSDAttributeUse)attributeContents.next();
XSDAttributeDeclaration xsdAttributeDeclaration =
xsdAttributeUse.getAttributeDeclaration();
if (xsdAttributeDeclaration.getURI().equals(SOAP_ENCODING_URI
+ "#" + "arrayType"))
Element attributeElement = xsdAttributeUse.getElement();
if (attributeElement != null &&
attributeElement.hasAttributeNS(WSDL_URI, "arrayType"))
String arrayType =
attributeElement.getAttributeNS(WSDL_URI, "arrayType");
int index = arrayType.indexOf("[");
if (index != -1)
String arrayTypeURI =
XSDConstants.lookupQName(attributeElement, arrayType.substring(0,
index));
XSDTypeDefinition itemTypeDefinition =
xsdAttributeUse.resolveTypeDefinitionURI(arrayTypeURI);
return itemTypeDefinition;
return null;
Mark Carman wrote:
> Dear All,
> Thanks a lot,
> Mark
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Mark,
<p>Here's some code that given a complex type that is a soap encoding array
type will return the resolved item type (or null otherwise):
<blockquote><tt>protected Object getSOAPEncodingArrayItemType(XSDComplexTypeDefinition
xsdComplexTypeDefinition)</tt>
<br><tt>{</tt>
<br><tt> if (xsdComplexTypeDefinition.getBaseTypeDefinition().getURI().e quals(SOAP_ENCODING_ARRAY)) </tt>
<br><tt> {</tt>
<br><tt> for (Iterator attributeContents = xsdComplexTypeDefinition.getAttributeContents().iterator();
attributeContents.hasNext(); )</tt>
<br><tt> {</tt>
<br><tt> XSDAttributeUse xsdAttributeUse
= (XSDAttributeUse)attributeContents.next();</tt>
<br><tt> XSDAttributeDeclaration xsdAttributeDeclaration
= xsdAttributeUse.getAttributeDeclaration();</tt>
<br><tt> if (xsdAttributeDeclaration.getURI().equals(SOAP_ENCODING_URI
+ "#" + "arrayType"))</tt>
<br><tt> {</tt>
<br><tt> Element attributeElement
= xsdAttributeUse.getElement();</tt>
<br><tt> if (attributeElement
!= null && attributeElement.hasAttributeNS(WSDL_URI, "arrayType"))</tt>
<br><tt> {</tt>
<br><tt> String arrayType
= attributeElement.getAttributeNS(WSDL_URI, "arrayType");</tt>
<br><tt> int index
= arrayType.indexOf("[");</tt>
<br><tt> if (index
!= -1)</tt>
<br><tt> {</tt>
<br><tt>
String arrayTypeURI = XSDConstants.lookupQName(attributeElement, arrayType.substring(0,
index));</tt>
<br><tt>
XSDTypeDefinition itemTypeDefinition = xsdAttributeUse.resolveTypeDefinitionURI(arrayTypeURI);</tt >
<br><tt>
return itemTypeDefinition;</tt>
<br><tt> }</tt>
<br><tt> }</tt>
<br><tt> }</tt>
<br><tt> }</tt>
<br><tt> }</tt><tt></tt>
<p><tt> return null;</tt>
<br><tt>}</tt></blockquote>
<br>
<p>Mark Carman wrote:
<blockquote TYPE=CITE>Dear All,
<p>I'm trying to obtain the (simple) type definitions of "elements" within
<br>soap encoded arrays. Here's an example of one such array declaration:
<p><xsd:attribute ref="soapenc:arrayType"
<br>
<p>Here the attribute, "arrayType" is a string, but the SOAP engine
<br>understands that the string really contains objects of type
<br>"typens:CustomerReview" as a single dimensional array. (Ugly way of
<br>encoding your data, I know, but people seem to use this construction!)
<p>My problem is, that when inspecting such an attribute, I want to resolve
<br>the "typens:CustomerReview" (simple) type definition and view its
<br>properties. Before calling the resolveSimpleTypeDefinition() method,
I
<br>need to find the URL which the namespace prefix "typens" represents.
I had
<br>a look in both the XSD and DOM apis and couldn't find a method to do
this.
<br>Does anybody know how to map prefixes to the URLs they represent? I'm
sure
<br>it must be really simple.
<p>Thanks a lot,
<p>Mark</blockquote>
</html>
--------------1588619BC5AD3F6387D487AD--
Re: namespace prefix to URL resolution [message #25900 is a reply to message #25819] |
Fri, 01 August 2003 07:31 |
Dear Ed,
thank you very much for your help!
Yours,
Mark
Ed Merks wrote:
> Mark,
> protected Object
> if
> String arrayType =
> if (index != -1)
> index));
> return null;
> Mark Carman wrote:
> > Dear All,
> > Thanks a lot,
> > Mark
Re: namespace prefix to URL resolution [message #575298 is a reply to message #25678] |
Ed Merks Messages: 33140 Registered: July 2009 |
Mark,
protected Object
if
String arrayType =
if (index != -1)
index));
return null;
Mark Carman wrote:
> Dear All,
> Thanks a lot,
> Mark
<html>
Mark,
<br><tt>{</tt>
<br><tt> {</tt>
<br><tt> {</tt>
<br><tt> {</tt>
<br><tt> {</tt>
<br><tt> int index
<br><tt> if (index
!= -1)</tt>
<br><tt> {</tt>
<br><tt>
index));</tt>
<br><tt>
<br><tt>
<br><tt> }</tt>
<br><tt> }</tt>
<br><tt> }</tt>
<br><tt> }</tt>
<br>
<br>
I
I had
this.
sure
<p>Thanks a lot,
</html>
Ed Merks
Re: namespace prefix to URL resolution [message #575410 is a reply to message #25819] |
Dear Ed,
Yours,
Mark
Ed Merks wrote:
> Mark,
> protected Object
> if
> String arrayType =
> if (index != -1)
> index));
> return null;
> Mark Carman wrote:
> > Dear All,
> > Thanks a lot,
> > Mark
Current Time: Thu Apr 25 06:18:12 GMT 2024
Powered by FUDForum. Page generated in 0.03959 seconds
