Home » Eclipse Projects » Equinox » Multiple instances of the Equinox servlet bridge break Syserr
Multiple instances of the Equinox servlet bridge break Syserr [message #1450757] Wed, 22 October 2014 22:15 Go to next message
Michael Yara is currently offline Michael YaraFriend
I work on a project that utilizes a plain Java application that launches an embedded Jetty web server which then launches several instances of the Equinox Servlet bridge. As I was debugging some code I noticed that Syserr was not being printed out to the console at all but Sysout was working just fine. I added the following code to the startup() method of one of my immediately activated components within one of the servlet bridge instances:
	new Timer().schedule(new TimerTask() {
		public void run() {
			System.out.println(System.err);
			System.err.println("Works");
	}, 0, 1000);
The following is the output of the test:
java.io.PrintStream@5ba91eec
Works
Works
org.apache.felix.gogo.runtime.threadio.ThreadPrintStream@5bc44dd2 <---Change 1
Works
Works
Works
Works
Works
Works
org.apache.felix.gogo.runtime.threadio.ThreadPrintStream@310031be <---Change 2
Works
org.apache.felix.gogo.runtime.threadio.ThreadPrintStream@41d5df31 <---Change 3
org.apache.felix.gogo.runtime.threadio.ThreadPrintStream@32a8ee87 <---Change 4
I noticed that the PrintStream that was set on System.err eventually changes to the Felix GoGo ThreadPrintStream which is to be expected since I am using Felix GoGo for my OSGI console.
The first issue I see is that the instance of ThreadPrintStream that is set changes three times. Looking at the source for org.apache.felix.service.threadio.ThreadIO.ThreadIOImpl I noticed this method:
    final ThreadPrintStream err = new ThreadPrintStream(this, System.err, true);
    final ThreadPrintStream out = new ThreadPrintStream(this, System.out, false);
    final ThreadInputStream in = new ThreadInputStream(this, System.in);
    public void start()
        if (System.out instanceof ThreadPrintStream)
            throw new IllegalStateException("Thread Print Stream already set");
        System.setOut(out);
        System.setIn(in);
        System.setErr(err);
Normally the if statement would trigger and prevent a new ThreadPrintStream from being set but this is not the case. The issue is that the class of the ThreadPrintStream instance stored in System.out is not the same class as the current ThreadPrintStream. This is due to the fact that the ThreadPrintStream class is loaded in different class loaders as I fire up new instances of the Equinox servlet bridge under Jetty. This causes a new ThreadPrintStream to be set each time I launch an instance of the Equinox servlet bridge.
The real issue is that after the third change of the PrintStream in System.err I loose all Syserr in the servlet. I am assuming that the issue is somehow related to the changing instance of ThreadPrintStream but I do not have any direct evidence for this yet.
I have tried reverting to the built in console using the property
[code]
osgi.console.enable.builtin=true
[\code]
but this just results in the following error:
!ENTRY org.eclipse.osgi 4 0 2014-10-22 16:03:02.783
!MESSAGE Could not find bundle: unknown
!STACK 0
org.osgi.framework.BundleException: Could not find bundle: unknown
	at org.eclipse.core.runtime.internal.adaptor.ConsoleManager.checkForConsoleBundle(ConsoleManager.java:58)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:333)
	at org.eclipse.equinox.servletbridge.FrameworkLauncher.start(FrameworkLauncher.java:411)
	at org.eclipse.equinox.servletbridge.BridgeServlet.init(BridgeServlet.java:83)
	at javax.servlet.GenericServlet.init(GenericServlet.java:244)
	at org.eclipse.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:582)
	at org.eclipse.jetty.servlet.ServletHolder.initialize(ServletHolder.java:372)
	at org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:847)
	at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:300)
	at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1359)
	at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1352)
	at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:744)
	at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:497)
	at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
	at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:125)
	at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:107)
	at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:60)
	at org.eclipse.jetty.server.handler.ScopedHandler.doStart(ScopedHandler.java:120)
	at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:785)
	at org.eclipse.jetty.util.component.ContainerLifeCycle.addBean(ContainerLifeCycle.java:289)
	at org.eclipse.jetty.util.component.ContainerLifeCycle.addBean(ContainerLifeCycle.java:221)
	at org.eclipse.jetty.util.component.ContainerLifeCycle.updateBeans(ContainerLifeCycle.java:771)
	at org.eclipse.jetty.server.handler.HandlerCollection.setHandlers(HandlerCollection.java:89)
	at org.eclipse.jetty.server.handler.ContextHandlerCollection.setHandlers(ContextHandlerCollection.java:144)
	at org.eclipse.jetty.server.handler.HandlerCollection.addHandler(HandlerCollection.java:155)
	at com.xmlnamespace.panel.server.deployment.ServerDeploymentManager.deployServer(ServerDeploymentManager.java:328)
	at com.xmlnamespace.panel.server.deployment.ServerDeploymentManager.startCommunicationManager(ServerDeploymentManager.java:251)
	at com.xmlnamespace.panel.server.Server.main(Server.java:330)
I feel that this is a bug in the Felix GoGo implementation but I am not sure if I should file a bug report with Equinox or Felix. Any help with this issue would be greatly appreciated as this is causing me quite the headache.
The following is a list of jars that make up the Equinox servlet bridge:
org.apache.felix.gogo.command_0.10.0.v201209301215.jar
org.apache.felix.gogo.runtime_0.10.0.v201209301036.jar
org.apache.felix.gogo.shell_0.10.0.v201212101605.jar
org.eclipse.equinox.cm_1.1.0.v20131021-1936.jar
org.eclipse.equinox.common_3.6.200.v20130402-1505.jar
org.eclipse.equinox.console_1.1.0.v20140131-1639.jar
org.eclipse.equinox.ds_1.4.200.v20131126-2331.jar
org.eclipse.equinox.http.registry_1.1.300.v20130402-1529.jar
org.eclipse.equinox.http.servlet_1.1.500.v20140318-1755.jar
org.eclipse.equinox.http.servletbridge_1.0.300.v20130327-1442.jar
org.eclipse.equinox.preferences_3.5.200.v20140224-1527.jar
org.eclipse.equinox.registry_3.5.400.v20140428-1507.jar
org.eclipse.equinox.util_1.0.500.v20130404-1337.jar
org.eclipse.osgi_3.10.0.v20140606-1445.jar
org.eclipse.osgi.services_3.4.0.v20140312-2051.jar
Re: Multiple instances of the Equinox servlet bridge break Syserr [message #1451182 is a reply to message #1450757] Thu, 23 October 2014 12:58 Go to previous messageGo to next message
Thomas Watson is currently offline Thomas WatsonFriend
In Luna (org.eclipse.osgi_3.10.0) we removed the built-in console altogether, so that is why trying to revert to it will not work. I think you should open a felix bug on this and post the link back here please.
I would guess that gogo may be closing the original stream somehow. Does your scenario involves shutting down one of the frameworks?
We should probably look at updating our version of gogo. I know command and runtime have been updated since 0.10.0. I'm not sure if the latest gogo runtime would fix the issue for you (http://mirrors.advancedhosters.com/apache//felix/org.apache.felix.gogo.runtime-0.12.1.jar), but it is worth a shot before you open the bug. Please report back here.
Thanks.
Re: Multiple instances of the Equinox servlet bridge break Syserr [message #1451258 is a reply to message #1451182] Thu, 23 October 2014 15:05 Go to previous message
Thank you for the reply.
We are not shutting down any of the framework instances. I have also tried upgrading GoGo with the latest stable directly from the Apache Felix project but I get the same results.
I will issue a bug report with Felix and post here.
Previous Topic:Eclipse RCP app no longer working with Java 8 update 25
Next Topic:Could not acquire the framework manipulator service
Current Time: Thu Apr 25 16:39:34 GMT 2024
Powered by FUDForum. Page generated in 0.03238 seconds
