Bundle.jar fails: Basedir xxx.jar is not a directory. [message #1450581] |
Wed, 22 October 2014 16:00 |
Tobias Bertelsen Messages: 25 Registered: October 2011 |
Junior Member |
Hi there.
Can someone help me with fixing this problem? I am getting this following error during my build (headless).
org.eclipse.core.runtime.CoreException: Basedir C:\path\to\target\platform\plugins\org.eclipse.equinox.simpleconfigurator_1.0.301.v20120828-033635.jar is not a directory
I am pretty sure it has something to do with the fact that we are modifying the simpleconfigurator bundle and applying it using a feature patch. Our setup has this structure:
Our.product
- our.product.feature
- *org.eclipse.runtime
- *org.eclipse.equinox.simpleconfigurator_1.0.301.v20120828-033635
- our.eclipse.runtime.patch
- org.eclipse.equinox.simpleconfigurator_1.0.302.qualifier
* = is in the target platform. Everything else are projects in the workspace.
We do not use Buckminster for materialization. The target platform is defined in a .target file and is based on folders.
When the build runs it fails on the action org.eclipse.equinox.simpleconfigurator:osgi.bundle$1.0.301.v20120828-033635#bundle.jar. I have attached a debugger to see whats goint on.
As far as I can see, the dependencies between the attributes of the feature, feature patch and plugins, are resolved correctly acording to the structure shown above.
The action is an ant actor, with the following field values:
actorName "ant"
actorProperties {buildFileId=buckminster.pdetasks, targets=recreate.jar}
always false
assignConsoleSupport true
cspec org.eclipse.equinox.simpleconfigurator:osgi.bundle$1.0.301.v20120828-033635
documentation null
filter null
name "bundle.jar"
prerequisites org.eclipse.equinox.simpleconfigurator:osgi.bundle$1.0.301.v20120828-033635#action.requirements
productAlias "action.output"
productBase ${buckminster.output}/
productFileCount -1
products [org.eclipse.equinox.simpleconfigurator_1.0.301.v20120828-033635.jar]
properties {}
publ true
upToDatePolicy DEFAULT
I can see that basedir for the ant script is set in the ant actor with this statement props.put("basedir", ctx.getComponentLocation().toOSString());, which does not seem to play well with jars from the target platform.
I hope some of you are able to help
Tobias
The entire stacktrace from the log is here:
!ENTRY org.eclipse.buckminster.core 1 293 2014-10-22 16:53:56.999
!MESSAGE [start org.eclipse.equinox.simpleconfigurator:osgi.bundle$1.0.301.v20120828-033635#bundle.jar]
INFO: [start org.eclipse.equinox.simpleconfigurator:osgi.bundle$1.0.301.v20120828-033635#bundle.jar]
[ant] Buildfile: C:\path\to\dobsheadless\configuration\org.eclipse.osgi\bundles\39\1\.cp\org\eclipse\buckminster\pde\antscr
ipts\build.xml
!ENTRY org.eclipse.buckminster.core 4 293 2014-10-22 16:54:40.066
!MESSAGE org.eclipse.core.runtime.CoreException: Basedir C:\path\to\target\platform\plugins\org.eclipse.equinox.simpleconfigurator_1.0.301.v20120828-0336
!STACK 1
at org.eclipse.buckminster.ant.AntRunner.handleInvocationTargetException(AntRunner.java:167)
at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:322)
at org.eclipse.buckminster.ant.actor.AntActor.internalPerform(AntActor.java:254)
at org.eclipse.buckminster.core.actor.AbstractActor.perform(AbstractActor.java:195)
at org.eclipse.buckminster.core.internal.actor.PerformManager$DirectActionInvocation.execute(PerformManager.java:143)
at org.eclipse.buckminster.core.internal.actor.PerformManager.internalPerform(PerformManager.java:454)
at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:293)
at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:305)
at org.eclipse.buckminster.core.commands.Perform.internalRun(Perform.java:108)
at org.eclipse.buckminster.core.commands.WorkspaceCommand.run(WorkspaceCommand.java:91)
at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(AbstractCommand.java:200)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:343)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:284)
at org.eclipse.buckminster.cmdline.Headless.start(Headless.java:358)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Caused by: Basedir C:\path\to\target\platform\plugins\org.eclipse.equinox.simpleconfigurator_1.0.301.v20120828-033635.jar is not a directory
at org.apache.tools.ant.Project.setBaseDir(Project.java:848)
at org.apache.tools.ant.Project.setBasedir(Project.java:829)
at org.apache.tools.ant.helper.ProjectHelper2$ProjectHandler.onStartElement(ProjectHelper2.java:841)
at org.apache.tools.ant.helper.ProjectHelper2$RootHandler.startElement(ProjectHelper2.java:600)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:509)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(XMLNSDocumentScannerImpl.java:379)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl$NSContentDriver.scanRootElementHook(XMLNSDocumentScannerImpl.java:605)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:3138)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:880)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:606)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:117)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:510)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:848)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:648)
at org.apache.tools.ant.helper.ProjectHelper2.parse(ProjectHelper2.java:307)
at org.apache.tools.ant.helper.ProjectHelper2.parse(ProjectHelper2.java:178)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.parseBuildFile(InternalAntRunner.java:350)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:642)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:498)
at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:318)
... 24 more
Edit: Added materialization description
[Updated on: Wed, 22 October 2014 16:03] Report message to a moderator
FUDForum. Page generated in 0.02955 seconds
