Home » Modeling » EMF » Add duplicated elements to EList
Re: Add duplicated elements to EList [message #1450114 is a reply to message #1449711] |
Wed, 22 October 2014 05:27   |
Ed Merks Messages: 31702 Registered: July 2009 |
Thomas,
Comments below.
On 21/10/2014 8:55 PM, Thomas Zwickl wrote:
> Hello,
> I've today encountered that although I've set the flag Unique for a
> reference in the EMF model to false, that I still cannot add
> duplicated objects. It's a one way reference where I want to add
> several objects, which can also be the same objects. The only thing
> that's interesting for me is the order the objects appear in the list.
> Does anyone know what's the reason why I cannot add duplicated
> objects, despite the fact that I deactivated uniqueness?
> I have already searched for the problem in the internet and
> encountered the following very old bug report, which still seems to be
> active:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=89325
Yes, it's an old issue. (Strange that I wasn't on the CC list.)
> Any ideas if this bug has already been resolved in one of the versions
> or if anyone is working on solving this problem?
No, not really.
> Any help or pointers would be appreciated.
It's clear from the implementation that the limitation is intentional.
As mentioned in there, the problem is that downstream assumptions in the
rest of the framework count on this. E.g., how does one specify a
RemoveCommand that removes the appropriate instance, or make sure that
the change recorder doesn't get confused, and that the cross reference
adapter knows to consider there could be more than one reference, so
removing one shouldn't necessarily forget about the reference? I'd
need to revisit much of the downstream framework to ensure that general
support for this generally works...
Of course can can specialize your list's getter so that its list allow
uniqueness and then hope for the best. It's often the, e.g., case
https://bugs.eclipse.org/bugs/show_bug.cgi?id=89325#c4, that folks
discover later that this non-uniqueness isn't really the best semantic
representation in the first place...
Ed Merks
Re: Add duplicated elements to EList [message #1450200 is a reply to message #1450114] |
Wed, 22 October 2014 07:40   |
Ed Willink Messages: 6985 Registered: July 2009 |
The non-Unique use case is certainly uncommon, hence the longevity of
the bug. But it is not unreasonable. EMF code generation is usually
accurate and so the associated EMF malfunction comes as a big surprise
and something of a debugging nightmare.
Consider the modeling of e.g. Map<K,V> using a positionally correlated
list of TemplateParameterType. This list is correctly non-unique since
there is no reason why Map<String,String> should be prohibited.
I have successfully avoided exactly this problem by code such as:
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated NOT FIXME workaround BUG 89325
@SuppressWarnings("serial")
public List<CGClass> getTemplateParameters() {
if (templateParameters == null) {
templateParameters = new EObjectEList<CGClass>(CGClass.class, this,
CGModelPackage.CG_CLASS__TEMPLATE_PARAMETERS)
protected boolean isUnique() {
return false;
return templateParameters;
Ed Willink
On 22/10/2014 06:27, Ed Merks wrote:
> Thomas,
> Comments below.
>> Hello,
>> active:
> No, not really.
Re: Add duplicated elements to EList [message #1450225 is a reply to message #1450200] |
Wed, 22 October 2014 08:10   |
Ed,
Comments below.
On 22/10/2014 9:40 AM, Ed Willink wrote:
> Hi
That's why it's not fixed and not closed as won't fix.
> EMF code generation is usually accurate and so the associated EMF
> malfunction comes as a big surprise and something of a debugging
> nightmare.
Associated malfunction?
Such a thing is modeled by Ecore itself.
> This list is correctly non-unique since there is no reason why
It's not a good example because of course you can have Map<Map<String,
String>, Map<String, String>>, i.e., these aren't simply references but
rather "expressions" that reference things, i.e., EGenericTypes as
modeled in Ecore.
> @Override
> @Override
> return false;
> Regards
> Ed Willink
So in your case, template parameters can't in turn make use of types
with template arguments; generally such things are recursively permitted.
A different example that comes to mind is modeling a method's signature,
java.lang.reflect.Method.getParameterTypes(). So yes, the problem does
arise; but even here, it's more likely this is derived from something
else, i.e., java.lang.reflect.Method.getGenericParameterTypes(), but of
course that wasn't the case before Java 5.0.
>> Thomas,
>> Comments below.
>>> Hello,
>>> active:
>> No, not really.
Ed Merks
Re: Add duplicated elements to EList [message #1450272 is a reply to message #1450225] |
Wed, 22 October 2014 09:06   |
On 22/10/2014 09:10, Ed Merks wrote:
> Ed,
In the deliberately simple example, the instantiation of Map<String,
String> is 'adjusted' to Map<String> since the duplicate String argument
object is a duplicate and so the extra copy is suppressed. With a wrong
object representation all sorts of failures such as matching list length
validation will follow.
Exactly the same could happen for Map<Map<String, String>, Map<String,
String>> if all types are globally unique; we get the unique constructed
types T1 and T2:
T1 := Map<String> rather than Map<String, String>
T2 := Map<T1> rather than Map<Map<String, String>, Map<String, String>>
Indeed Ecore has related functionality but that is nothing to do with
the deliberately simple example.
Yes, this occurs with parameter lists too. Perhaps the common theme is
that support for non-unique positional lists is currently pending.
And yes, keyed lists are fundamentally better, but I see little
likelihood of major languages such as Java requiring users to write code
such as
myString.substring(endIndex := 5, beginIndex := 0)
and so avoid the hazards of misaligned arguments. Non-unique positional
lists are appropriate.
Ed Willink
Re: Add duplicated elements to EList [message #1450328 is a reply to message #1450272] |
Wed, 22 October 2014 10:33  |
Thomas Zwickl Messages: 37 Registered: May 2014 |
Member |
so first thanks for all comments now it is clear for me why this problem is really hard to solve, because of the downstream assumption the entire framework depends on.
We have now implemented the provided solution form Merks and for our case it is working exactly as we intended it.
I know that this can be dangerous because methods like remove or indexOf won't work any more in their appropriate way, but in our case we don't need this methods we just need to iterate over the list and check in which order the elements appear ...
So more or less this solution was exactly what we were looking for ...
CGModelPackage.CG_CLASS__TEMPLATE_PARAMETERS) {
return false;
Thomas
[Updated on: Wed, 22 October 2014 10:50] Report message to a moderator
Current Time: Sun Jan 17 17:28:56 GMT 2021
Powered by FUDForum. Page generated in 0.02387 seconds
