Home » Eclipse Projects » Eclipse Platform » Eclipse Indigo (3.8) does not start with Mac 10.10
Eclipse Indigo (3.8) does not start with Mac 10.10 [message #1448903] Mon, 20 October 2014 12:03 Go to next message
I have been using Indigo build for my application. Since i have updated to Mac 10.10, i get the message to install old legacy java 6 version.
If i download the latest elipse then it does not give this message. How can i update my indigo to get rid of this message? Also I have a RCP application developed in indigo and it also gives the message to install java 6 to run the app.
Do you know how to fix it in indigo?
[Updated on: Mon, 20 October 2014 12:14] by Moderator
Re: Eclipse Indigo does not start with Mac 10.10 [message #1449002 is a reply to message #1448903] Mon, 20 October 2014 15:33 Go to previous messageGo to next message
The Yosemite upgrade would have removed Apple's Java 6 that would have
been installed when running Mavericks. It's probably a simple matter of
reinstalling Java 6 so it is back on your system.
Re: Eclipse Indigo does not start with Mac 10.10 [message #1449334 is a reply to message #1449002] Tue, 21 October 2014 03:41 Go to previous messageGo to next message
yes it seems to be work with java 6. But i want to have latest java version on my machine and i want to run eclipse with java 8. If i use latest version of eclipse then i do not need to install java 6 as it works with java 8.
Is there any way to run indigo with java 8 on Mac 10.10?
Re: Eclipse Indigo does not start with Mac 10.10 [message #1713321 is a reply to message #1449334] Tue, 03 November 2015 05:26 Go to previous message
Dear ModelGeek Mising nameFriend,
I have same problem with this issue. If you've solved this issue, Could you tell me your solution?
Thank you.
Previous Topic:How to get ""org.eclipse.ui.navigator.navigatorContent" extension point
Next Topic:Define save action in plugin
Current Time: Tue Apr 22 13:06:16 EDT 2025
Powered by FUDForum. Page generated in 0.06384 seconds
