Home » Language IDEs » Java Development Tools (JDT) » [JDT bug?] Filtered resources not saved
[JDT bug?] Filtered resources not saved [message #258941] Tue, 03 March 2009 18:22 Go to next message
Originally posted by: rosec.messagingdirect.com
For some reason JDT is configured to filter out *.xml from the source
tree when compiling. Why? I don't know... but that's not the bug.
I have removed the *.xml from the Filtered Resources field
(Window->Preferences: Java->Compiler->Building->Output Folder) and
rebuilt the whole workspace... and then after I have done so, the next
time I restart Eclipse the filtered resources list includes *.xml again.
This seems like a fairly obvious bug to me, but I'm open to explanations
of why it's PEBKAC before I submit it. Should I issue it?
Eclipse SDK (Linux)
java.vendor.url=http://java.sun.com/
java.version=1.6.0_11
Version: 3.4.1
Build id: M20080911-1700
Of course I can provide a plugin list if needed.
Chris Rose
Developer Planet Consulting Group
(780) 577-8433
crose@planetci.com
Re: [JDT bug?] Filtered resources not saved [message #258945 is a reply to message #258941] Tue, 03 March 2009 21:04 Go to previous messageGo to next message
Please open a bug report against JDT/Core with all steps to reproduce.
Olivier
Re: [JDT bug?] Filtered resources not saved [message #258949 is a reply to message #258941] Wed, 04 March 2009 08:49 Go to previous messageGo to next message
Maybe you're facing bug 230050:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=230050
Mauro.
Re: [JDT bug?] Filtered resources not saved [message #258958 is a reply to message #258949] Wed, 04 March 2009 19:50 Go to previous messageGo to next message
Mauro;
That is exactly the issue. Thanks, I won't bother submitting a bug,
since it looks like it's fixed. I'll pull down a TPTP nightly, though :)
> Mauro.
Chris Rose
(780) 577-8433
crose@planetci.com
Re: [JDT bug?] Filtered resources not saved [message #258966 is a reply to message #258958] Thu, 05 March 2009 07:06 Go to previous messageGo to next message
I think TPTP 4.5.2 should contain the fix and it has been released. So,
you shouldn't need any nightly.
I'm glad I've been of help.
Mauro.
Re: [JDT bug?] Filtered resources not saved [message #956225 is a reply to message #258966] Wed, 24 October 2012 06:38 Go to previous message
I do have the same problem but not with *.xml. This time with *.ecore
After restarting Eclipse all the settings are resetting back.
Any advice would be highly appreciated.
Previous Topic:Juno Hangs on Large Project
Next Topic:ECJ usage in eclipse plugin
Current Time: Tue Jun 24 22:18:05 EDT 2025
Powered by FUDForum. Page generated in 0.30474 seconds
