Home » Newcomers » Newcomers » Newcomer to Eclipse and semi newcomer to the prgramming world.(I have seem to found quite a few problems with Eclipse the few times I've had it up and running.)
icon6.gif  Newcomer to Eclipse and semi newcomer to the prgramming world. [message #1447112] Fri, 17 October 2014 20:28 Go to next message
Kristjan Stefansson is currently offline Kristjan StefanssonFriend
Hi, I use Linux as my main OS, but I also have two Windows 7 Ultimate running at all times, I only tried Eclipse on Linux and this is about that.
I'm learning programming and have been getting into computers since 2009. I've set up a programming environment in Linux a few times and when setting up Eclipse, found problems. I often end up with Eclipse not starting anymore.
This is what I do, I setup the environment with a lot of tools and IDE's for programming and when I set up Eclipse I install it from the distro repo and begin to add software in "install new software", I remember on two ocasions that it ended with Eclipse always hanging at the loading window(the small one). The other setup I remember that, when trying to add alot of software, the program couldn't install any software.
Do you have any guidelines for me?
I program in C, C++, C#, Java and Python. Still only learning C and C#, and haven't started the others, those are the languages I'll be using.
My distro's are Fedora and Debian.
Note that I have never actually programmed in Eclipse, but have heard good things about it so I want to try it and see if it becomes one of my tools.
Re: Newcomer to Eclipse and semi newcomer to the prgramming world. [message #1447611 is a reply to message #1447112] Sat, 18 October 2014 15:59 Go to previous messageGo to next message
David Wegener is currently offline David WegenerFriend
> starting anymore.
> tools.
Don't install from the distribution repository. Download directly from
the Eclipse web site and unzip the download to a folder in your home
directory. I have a separate folder for each Eclipse release train
~/kepler, ~/luna, etc.
Edit the eclipse.ini file to explicitly point to an installed JDK/JRE.
Re: Newcomer to Eclipse and semi newcomer to the prgramming world. [message #1448825 is a reply to message #1447611] Mon, 20 October 2014 13:51 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
Did you read the Announcement message at the top of this forum, titled "Linux + Eclipse users, read this!" - the gist, don't use Eclipse installed from a Linux repo, just download it from www.eclipse.org
[Updated on: Mon, 20 October 2014 13:52]
Report message to a moderator
Re: Newcomer to Eclipse and semi newcomer to the prgramming world. [message #1449035 is a reply to message #1448825] Mon, 20 October 2014 20:42 Go to previous message
I didn't notice it before after my post.
Previous Topic:plugin 'org.eclipse.equinox.p2.sdk.feature.group' is null
Next Topic:help please for the configuration jdk jre on eclipse
Current Time: Sun Jan 26 17:04:11 GMT 2020
Powered by FUDForum. Page generated in 0.03762 seconds
