Home » Eclipse Projects » Oomph » How to provide a specific nature to every project
How to provide a specific nature to every project [message #1446910] Fri, 17 October 2014 13:50 Go to next message
Aurélien Pupier is currently offline Aurélien PupierFriend
What would be the best solution to provide a specific nature to imported project?
(My goal is currently to add the Sonar nature)
Currently, my projects are imported as Maven projects.
Should I create a a custom setup task?
Should I simply use a "String substitution" setup task on .project files?
Should I'd rather commit the .project file? (the battle will be hard to win for every projects :s)
Thanks by advance for your advice
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Re: How to provide a specific nature to every project [message #1446968 is a reply to message #1446910] Fri, 17 October 2014 15:27 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 17.10.2014 um 15:51 schrieb Aurelien Pupier:
We generally recommend to commit the .project files and we do that ourselves. Problem solved ;-)
Cheers
/Eike
http://www.esc-net.de
Re: How to provide a specific nature to every project [message #1447000 is a reply to message #1446968] Fri, 17 October 2014 16:34 Go to previous message
Hi Eike,
thanks for your answer, I will try to convince my colleagues.
Previous Topic:"Do you trust these certificates"-Dialog does not popup during install
Next Topic:Error when launching "Oomph Installer" From Eclipse Workspace
Current Time: Fri Oct 30 02:57:34 GMT 2020
Powered by FUDForum. Page generated in 0.02152 seconds
