Home » Modeling » QVT-OML » QVT standard library extension
QVT standard library extension [message #1445558] Wed, 15 October 2014 15:58 Go to next message
ModelGeek Mising name is currently offline ModelGeek Mising nameFriend
I have been using OCL in my application and i have done extension in OCL standard library (OCL-2.5.oclstdlib) to introduce some new operations. OCL standard library extesion works fine.
I would like to use QVTo in my application to translate models. I would like to extend the Standard library for QVTo as well to introduce some operations. Do i need to adopt the similar methodology? Is there any help or tutorial available?
Re: QVT standard library extension [message #1445650 is a reply to message #1445558] Wed, 15 October 2014 18:51 Go to previous messageGo to next message
Migration of Eclipse QVTo to exploit the Pivot-based OCL rather than
Ecore-based OCL is planned/underway. The underlying autogeneration of
OCL tooling from OCL 2.5 specification candidate models should be in
place for Mars, allowing OCL-extending projects to exploit it for
Mars+1. Until then extending the QVTo library must use painful hard
coded approaches.
Sorry.
Ed Willink
> Cheers,
Re: QVT standard library extension [message #1446043 is a reply to message #1445650] Thu, 16 October 2014 09:23 Go to previous messageGo to next message
thanks for information.
Do you know when Mars+1 will be avaiable earliest? Actually we need to plan different activities so it will be great to have some clue about approxinmate date.
thanks again!
Re: QVT standard library extension [message #1446096 is a reply to message #1446043] Thu, 16 October 2014 10:55 Go to previous message
Eclipse releases have been the fourth Wednesday in June for many years,
so very late June 2016 is likely.
Milestone builds will be available well before that, but there are too
many challenges to make confident predictions at this point.
Ed Willink
> approxinmate date.
> thanks again!
> Cheers,
Previous Topic:Build with Jenkins
Next Topic:Error while generating Diagram Editor Gen Model
Current Time: Mon Mar 30 14:27:36 GMT 2020
Powered by FUDForum. Page generated in 0.02445 seconds
