Home » Modeling » Papyrus » Papyrus installation on Eclipse Luna
Papyrus installation on Eclipse Luna [message #1443838] Mon, 13 October 2014 09:15 Go to next message
Loïc FRETTE is currently offline Loïc FRETTEFriend
I'm trying to install Papyrus on my computer. I have download Eclipe Modeling Tool (on Luna Release SR1).
I click on Install More Modeling Component -> Selection of Papyrus
Error appears about hyperlinks. I try to access to the link (http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/luna/) directly with internet explorer -> Not found
Do you have any idea how to install Papyrus on my PC ?
Thanks you.
Loïc
Re: Papyrus installation on Eclipse Luna [message #1444003 is a reply to message #1443838] Mon, 13 October 2014 14:22 Go to previous messageGo to next message
Mickael ADAM is currently offline Mickael ADAMFriend
Member
hi,
http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/luna/ is the update site.
To install papyrus go to Help>Install new software > paste the update site and select Papyrus UML.
Mickaël
Re: Papyrus installation on Eclipse Luna [message #1444012 is a reply to message #1444003] Mon, 13 October 2014 14:31 Go to previous messageGo to next message
Hi Mickaël,
Thanks for the answer.
I've already try to install a new software with this link. I join a picture of the error.
That's why I can't add Papyrus on my computer. Do you have already see this error ?
Loïc
Re: Papyrus installation on Eclipse Luna [message #1444017 is a reply to message #1443838] Mon, 13 October 2014 14:40 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
Hi Loïc,
This link is not a web page; it is an Eclipse update site:
Not Found
We're sorry, the page or file cannot be found. Here are some reasons why:
    This is an Eclipse Update site/p2 repository; you must access it from Eclipse (see how).
So, it is expected that you can't access it via a web browser.
The update site is valid and exists.
The solution Mickaël suggested should work, but with Eclipse Modeling you don't even need to use update sites: once Eclipse Modeling is started, just go to Help > Install Modeling Components, then select Papyrus, then finish. That's it!
Camille
Camille Letavernier
Re: Papyrus installation on Eclipse Luna [message #1444028 is a reply to message #1444017] Mon, 13 October 2014 14:52 Go to previous messageGo to next message
Hi Camille,
I understand for the update site, thanks for the explication.
The solution suggested by Mickaël was the first solution I tried. When I try to install Papyrus with "Install Modeling Components" an error appears.
That's why I started to look on update site.
Loïc
Re: Papyrus installation on Eclipse Luna [message #1444033 is a reply to message #1444028] Mon, 13 October 2014 14:58 Go to previous messageGo to next message
Member
I'me not sure but apparently there is an error on your network. try to configure the proxy.
Re: Papyrus installation on Eclipse Luna [message #1444034 is a reply to message #1444028] Mon, 13 October 2014 15:00 Go to previous messageGo to next message
Apparently you need to go through a proxy to get HTTP access, so you need to configure this proxy in Eclipse as well. Not sure how it works exactly, but you should have a look at the Eclipse Preferences, under General > Network Connections
HTH,
Camille
Camille Letavernier
Re: Papyrus installation on Eclipse Luna [message #1444046 is a reply to message #1444034] Mon, 13 October 2014 15:11 Go to previous messageGo to next message
BTW, if you can't properly configure the proxy in Eclipse, you can download the zipped update site here:
https://www.eclipse.org/papyrus/downloads/ (Choose 1.0.1 under Latest Releases)
then use Help > Install new software > Add... > Archive...
Camille
Camille Letavernier
Re: Papyrus installation on Eclipse Luna [message #1444519 is a reply to message #1444046] Tue, 14 October 2014 07:19 Go to previous messageGo to next message
In fact, that was my entreprise network which not allowed the connection.
I did it myself on my own PC and it works.
Thanks for your time, sorry for the inconvenience.
Loïc
Re: Papyrus installation on Eclipse Luna [message #1736965 is a reply to message #1444003] Mon, 04 July 2016 17:14 Go to previous messageGo to next message
jagdeep kaur is currently offline jagdeep kaurFriend
http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/kepler
i found errors when i was trying to install new softwares in eclipse.
  • Attachment: error.jpg
    (Size: 177.34KB, Downloaded 231 times)
Re: Papyrus installation on Eclipse Luna [message #1737230 is a reply to message #1736965] Wed, 06 July 2016 13:40 Go to previous message
Benoit Maggi is currently offline Benoit MaggiFriend
I can reach the kepler update site without problem.
Are you behind a corporate firewall?
Previous Topic:Can´t run Papyrus in OS X 10.9.5
Next Topic:ClassNotFound when adding a Matcher to an ElementTypesConfiguration
Current Time: Thu Aug 05 06:07:48 GMT 2021
Powered by FUDForum. Page generated in 0.02394 seconds
