No repository found at http://download.eclipse.org/efxclipse/compiler-released. [message #1443823] |
Mon, 13 October 2014 04:49  |
Hello Tom,
I've installed
e(fx)clipse - IDE - Updatesite - http://download.eclipse.org/efxclipse/updates-released/1.0.0/site
via the Eclipse "Install New Software"-function.
Now, when I want do perform "Check for Updates" I get the following error during the update-check-process:
Furthermore, when running the
File -> New -> Other -> JavaFX -> New FXGraph Wizard
I get the following error:
Failed to create injector for org.eclipse.fx.ide.fxgraph.FXGraph ExtensionFactory: org.eclipse.fx.ide.fxgraph.ui.FXGraphExecutableExtensionFactory
Seems, as if the installation went somehow wrong. Do you have any hints?
I have syntax highlighting support for fxml but no edit time error hints.
I was looking for your fxml-compiler, but didn't find a download-link for the 1.0.0-e(fx)clipse version, only for the 0.9.0-version, but I didn't want to mix that with 1.0.0 version, so I didn't install that.
Thanks & Greetings
Thomas
Re: No repository found at http://download.eclipse.org/efxclipse/compiler-released. [message #1444000 is a reply to message #1443823] |
Mon, 13 October 2014 10:19   |
On 13.10.14 16:09, Thomas Gawehn wrote:
> Hello Tom,
> I've installed
http://download.eclipse.org/efxclipse/compiler-released is not a p2 repo
so it makes no sense that it is in the update site. I have no idea how
and why this site could have been added to the p2-repos to search for
updates.
> ExtensionFactory:
My wild guess is that this fails because of a mismatch between installed
Xbase you have and the one we require. What's the version of Xtext/Xtend
you have installed?
... the XML-Editor should not be affected by the FXGraph problems it does
not need that at all.
Unfortunately the 1.0.0 release of the compiler is broken - I'm
currently working on that so that at least the nightly compiler stuff is
in shape when we release 1.1.0 so even if I'd provide you the link it
would not be functional :-(
Tom
Re: No repository found at http://download.eclipse.org/efxclipse/compiler-released. [message #1444069 is a reply to message #1444000] |
Mon, 13 October 2014 11:39   |
FYI - a sample project with a working fxml-compiler is checked into the
repo at
http://git.eclipse.org/c/efxclipse/org.eclipse.efxclipse.git/tree/demos/org.eclipse.fx.samples.fxml.compiler
Tom
>> Hello Tom,
>> I've installed
> updates.
>> ExtensionFactory:
> you have installed?
> Tom
Re: No repository found at http://download.eclipse.org/efxclipse/compiler-released. [message #1451021 is a reply to message #1444473] |
Thu, 23 October 2014 03:56  |
The nightly build of the compiler has been restored you can grab the
latest compiler suite from
http://download.eclipse.org/efxclipse/compiler-nightly/org.eclipse.fx.fxml.compiler_1.0.0-SNAPSHOT.jar
Tom
On 14.10.14 07:46, Thomas Gawehn wrote:
> Tom,
> many thanks for your support.
> Quote:
>> you have installed?
> My installed version of Xtext is
> Xtext Redistributable
> 2.7.2.v201409160908
> org.eclipse.xtext.redist.feature.group
> I've also made a clean new download of Eclipse Luna 4.4.1 and then
> installed only efxclipse 1.0.0 and the above Xtext-package ...
> Quote:
>> hints.
> So FXML-error reporting directly on the FXML-source is not available?
> https://www.eclipse.org/efxclipse/fxml_tooling.png
> let one suppose it would exist ...
> Quote:
>> would not be functional :(
> So looking really forward for the 1.1.0-version ;) ... as the compiler
> will give us a good understanding of using and modeling JavaFX widgets
> and comparing FXML to JavaFX-classes!
FUDForum. Page generated in 0.08075 seconds
