Re: Error .metadata\.log. when opening Eclipse [message #1440492 is a reply to message #1440485] |
Wed, 08 October 2014 12:40 |
latronda Washington Messages: 11 Registered: March 2014 |
the Error log within Eclipse gives this:
!SESSION 2014-10-03 10:33:28.115 -----------------------------------------------
eclipse.buildId=M20110210-1200
java.version=1.6.0_45
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY com.tririga.platform.birt.preferences 1 0 2014-10-03 10:33:44.277
!MESSAGE Injecting out preferences into the TriDatasetProperties...
!ENTRY com.tririga.platform.birt.preferences 1 0 2014-10-03 10:33:44.293
!MESSAGE Injected our preferences into the TriDatasetProperties.
!MESSAGE TRIRIGA Plugin started.
!ENTRY org.eclipse.ui.workbench 4 0 2014-10-03 11:39:26.779
!MESSAGE Widget disposed too early!
!STACK 0
java.lang.RuntimeException: Widget disposed too early!
at org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDisposed(WorkbenchPartReference.java:172)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:123)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Widget.release(Widget.java:808)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:872)
at org.eclipse.swt.widgets.Widget.release(Widget.java:811)
at org.eclipse.swt.widgets.Canvas.releaseChildren(Canvas.java:167)
at org.eclipse.swt.widgets.Decorations.releaseChildren(Decorations.java:773)
at org.eclipse.swt.widgets.Shell.releaseChildren(Shell.java:1267)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:446)
at org.eclipse.swt.widgets.Decorations.dispose(Decorations.java:447)
at org.eclipse.swt.widgets.Shell.dispose(Shell.java:714)
at org.eclipse.swt.widgets.Display.release(Display.java:3707)
at org.eclipse.swt.graphics.Device.dispose(Device.java:295)
at org.eclipse.swt.widgets.Display.messageProc(Display.java:3188)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2454)
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:497)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4253)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1598)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2038)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4886)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3024)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3652)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.jface.dialogs.MessageDialog.open(MessageDialog.java:334)
at org.eclipse.jface.dialogs.MessageDialogWithToggle.open(MessageDialogWithToggle.java:114)
at org.eclipse.jface.dialogs.MessageDialogWithToggle.openOkCancelConfirm(MessageDialogWithToggle.java:209)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAdvisor.promptOnExit(IDEWorkbenchWindowAdvisor.java:198)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor$2.handleEvent(IDEWorkbenchAdvisor.java:164)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4240)
at org.eclipse.swt.widgets.Display.messageProc(Display.java:3201)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
!STACK 0
!STACK 0
!STACK 0
!ENTRY org.eclipse.ui 4 0 2014-10-03 11:39:26.795
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.preShutdown(IDEWorkbenchAdvisor.java:352)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1035)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:1032)
at org.eclipse.ui.internal.Workbench$25.run(Workbench.java:1276)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:52)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1274)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1246)
at org.eclipse.ui.internal.Workbench$61.handleEvent(Workbench.java:2508)
!SESSION 2014-10-06 11:29:53.457 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2014-10-06 11:29:56.311
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY com.tririga.platform.birt.preferences 1 0 2014-10-06 11:29:58.901
!ENTRY org.eclipse.birt.data 4 1001 2014-10-06 11:54:04.606
!MESSAGE A BIRT exception occurred.
!STACK 0
org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot get the result set metadata.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
SQL error #1:Incorrect syntax near 'Label'.
java.sql.SQLException: Incorrect syntax near 'Label'.
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:52)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:108)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:84)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:414)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getProjectedColumns(PreparedStatement.java:377)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.doGetMetaData(PreparedStatement.java:347)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.execute(PreparedStatement.java:563)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.execute(DataSourceQuery.java:923)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:441)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1103)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:173)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultMetaData(QueryResults.java:133)
at org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHelper.getRuntimeMetaData(DataSetMetaDataHelper.java:193)
at org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHelper.getRealMetaData(DataSetMetaDataHelper.java:152)
at org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHelper.getDataSetMetaData(DataSetMetaDataHelper.java:114)
at org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHelper.refreshMetaData(DataSetMetaDataHelper.java:369)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.refreshMetaData(DataRequestSessionImpl.java:407)
at org.eclipse.birt.report.designer.data.ui.dataset.ExternalUIUtil.updateColumnCache(ExternalUIUtil.java:104)
at org.eclipse.birt.report.designer.data.ui.providers.DefaultDataServiceProvider.updateColumnCache(DefaultDataServiceProvider.java:107)
at org.eclipse.birt.report.designer.internal.ui.data.DataService.updateColumnCache(DataService.java:137)
at org.eclipse.birt.report.designer.data.ui.dataset.DataSetUIUtil.updateColumnCache(DataSetUIUtil.java:98)
at org.eclipse.birt.report.designer.data.ui.dataset.DataSetEditor.okPressed(DataSetEditor.java:685)
at org.eclipse.birt.report.designer.data.ui.property.AbstractPropertyDialog.buttonPressed(AbstractPropertyDialog.java:646)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.birt.report.designer.ui.dialogs.BaseDialog.open(BaseDialog.java:111)
at org.eclipse.birt.report.designer.data.ui.actions.NewDataSetAction.editDataSet(NewDataSetAction.java:237)
at org.eclipse.birt.report.designer.data.ui.actions.NewDataSetAction.createNewDataSet(NewDataSetAction.java:196)
at org.eclipse.birt.report.designer.data.ui.actions.NewDataSetAction.run(NewDataSetAction.java:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:471)
at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaUsingDefaultPolicy(Statement.java:378)
at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaData(Statement.java:320)
at org.eclipse.birt.report.data.oda.jdbc.bidi.BidiStatement.getMetaData(BidiStatement.java:56)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doGetMetaData(OdaQuery.java:412)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.getMetaData(OdaQuery.java:379)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:407)
... 60 more
Caused by: java.sql.SQLException: Incorrect syntax near 'Label'.
at net.sourceforge.jtds.jdbc.SQLDiagnostic.addDiagnostic(SQLDiagnostic.java:368)
at net.sourceforge.jtds.jdbc.TdsCore.tdsErrorToken(TdsCore.java:2820)
at net.sourceforge.jtds.jdbc.TdsCore.nextToken(TdsCore.java:2258)
at net.sourceforge.jtds.jdbc.TdsCore.getMoreResults(TdsCore.java:632)
at net.sourceforge.jtds.jdbc.JtdsStatement.executeSQLQuery(JtdsStatement.java:477)
at net.sourceforge.jtds.jdbc.JtdsPreparedStatement.executeQuery(JtdsPreparedStatement.java:776)
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:467)
... 66 more
!SUBENTRY 1 org.eclipse.birt.data 1 1001 2014-10-06 11:54:04.621
!MESSAGE Plug-in Provider:Eclipse.org
!MESSAGE Plug-in Name:BIRT Data Engine
!MESSAGE Plug-in ID:org.eclipse.birt.data
!MESSAGE Version:2.6.2.r262_v20110215
!SUBENTRY 1 org.eclipse.birt.data 4 1001 2014-10-06 11:54:04.621
!MESSAGE Error Code:odaconsumer.CannotGetResultSetMetaData
!MESSAGE Error Message:Cannot get the result set metadata.
!ENTRY org.eclipse.birt.data 4 1001 2014-10-06 11:54:25.089
!STACK 0
at org.eclipse.birt.report.designer.data.ui.providers.EditableDataSetNodeProvider.performEdit(EditableDataSetNodeProvider.java:102)
at org.eclipse.birt.report.designer.internal.ui.views.DefaultNodeProvider.performRequest(DefaultNodeProvider.java:442)
at org.eclipse.birt.report.designer.internal.ui.views.actions.EditAction.doAction(EditAction.java:90)
at org.eclipse.birt.report.designer.internal.ui.views.actions.AbstractElementAction.run(AbstractElementAction.java:70)
at org.eclipse.birt.report.designer.internal.ui.views.RenameListener.doubleClick(RenameListener.java:214)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:824)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:822)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1421)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1225)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:238)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:235)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:296)
... 68 more
... 74 more
!SUBENTRY 1 org.eclipse.birt.data 1 1001 2014-10-06 11:54:25.089
!SUBENTRY 1 org.eclipse.birt.data 4 1001 2014-10-06 11:54:25.089
!ENTRY org.eclipse.wst.sse.ui 4 4 2014-10-06 12:25:19.961
!MESSAGE problem with reconciling
!STACK 0
at org.eclipse.wst.sse.ui.internal.projection.AbstractStructuredFoldingStrategy.markInvalidAnnotationsForDeletion(AbstractStructuredFoldingStrategy.java:294)
at org.eclipse.wst.sse.ui.internal.projection.AbstractStructuredFoldingStrategy.reconcile(AbstractStructuredFoldingStrategy.java:194)
at org.eclipse.wst.sse.ui.internal.reconcile.DocumentRegionProcessor.process(DocumentRegionProcessor.java:312)
at org.eclipse.wst.sse.ui.internal.reconcile.StructuredRegionProcessor.process(StructuredRegionProcessor.java:248)
at org.eclipse.wst.sse.ui.internal.reconcile.DirtyRegionProcessor.run(DirtyRegionProcessor.java:667)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
!SESSION 2014-10-06 13:31:16.956 -----------------------------------------------
!ENTRY com.tririga.platform.birt.preferences 1 0 2014-10-06 13:31:28.687
!ENTRY com.tririga.platform.birt.preferences 1 0 2014-10-06 13:31:28.952
!ENTRY com.tririga.platform.birt.preferences 1 0 2014-10-06 13:31:28.968
!ENTRY org.eclipse.ui.workbench 4 0 2014-10-06 15:52:56.390
!STACK 0
!SESSION 2014-10-08 06:50:24.779 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2014-10-08 06:50:31.456
!ENTRY com.tririga.platform.birt.preferences 1 0 2014-10-08 06:50:38.040
!ENTRY com.tririga.platform.birt.preferences 1 0 2014-10-08 06:50:38.055
FUDForum. Page generated in 0.03711 seconds
