Home » Newcomers » Newcomers » Nanomind fail(Errors in Eclipse files Nanomind)
Nanomind fail [message #1439618] Tue, 07 October 2014 10:32 Go to next message
Cristobal Chaves is currently offline Cristobal ChavesFriend
Hi, I'm working with Nanomind in Eclipse and I have some problems .Currently I added the libraries Nanomind and libraries Arm, but the errors continue. These are the errors that I have currently. You have any idea what library I should add or do to make it work.
List of errors:
configTICK_RATE_HZ
xTaskWoken
xSemaphoreTake
xSemaphoreGive
xHigherPriorityTaskWoken
portTickType
portBASE_TYPE
portTICK_RATE_MS
port_MAX_DELAY
port_STACK_TYPE
portTickType
CSP_BASE_TYPE
CSP_MAX_DELAY
Thank you,
  • Attachment: errors.png
    (Size: 236.83KB, Downloaded 103 times)
Re: Nanomind fail [message #1439849 is a reply to message #1439618] Tue, 07 October 2014 15:40 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
Did you read the "Sticky" announcement at the top of this forum, regarding C/C++ questions?
Re: Nanomind fail [message #1439898 is a reply to message #1439849] Tue, 07 October 2014 16:54 Go to previous messageGo to next message
I did not find any ads "Sticky", in relation to questions of C / C ++. Maybe you can recommend me to exhibit my question, I'm new to this forum.
Thank you for replying.
Re: Nanomind fail [message #1440169 is a reply to message #1439898] Wed, 08 October 2014 02:52 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
You'll find more and better C/C++ expertise in the Eclipse CDT forum
than in the newcomers forum. This one is just to help with installation,
using the workbench, etc.
Re: Nanomind fail [message #1440429 is a reply to message #1440169] Wed, 08 October 2014 10:55 Go to previous messageGo to next message
Thanks for the information
Re: Nanomind fail [message #1440532 is a reply to message #1439898] Wed, 08 October 2014 13:32 Go to previous message
On the Newcomers forum main page, at the top are a few Announcement posts that are "sticky" (that means they are always kept at the top). One is titled: Announcement: C/C++ Eclipse User Info
Previous Topic:Avoid "The method ... can potentially be declared as static" warning
Next Topic:Bookmarks
Current Time: Tue Jul 14 08:33:41 GMT 2020
Powered by FUDForum. Page generated in 0.03052 seconds
