Home » Archived » BIRT » Changing the Parameter Page to a Horizontal Layout?
Changing the Parameter Page to a Horizontal Layout? [message #255870] Thu, 20 September 2007 14:07 Go to next message
Raishad is currently offline RaishadFriend
Member
Has anyone had any experience in changing the Parameter Page for the web
viewer to a horizontal layout as opposed to the normal vertical layout?
What I would like to do is to prevent the use from scrolling - by making
the paramter page wider and by making the parameters first fill up
horizontally before going vertically.
What files would I need to look at to change the normal behavior?
Thanks for any help
Raishad
Re: Changing the Parameter Page to a Horizontal Layout? [message #255874 is a reply to message #255870] Thu, 20 September 2007 14:21 Go to previous message
Raishad,
Look at the ParameterDialogFragment.jsp and the individual parameter
type fragments. They are placed in Table rows. You could modify this to
mod the behavior. You may also want to look at the new tag libs.
Take a look at this blog entry.
http://birtworld.blogspot.com/2007/09/22-birt-tag-library-bu ilding-custom.html
Jason
Raishad wrote:
> Thanks for any help
> Raishad
Previous Topic:BIRT Report
Next Topic:Generic/Default event handler class for all datasets
Current Time: Tue Apr 16 10:18:56 GMT 2024
Powered by FUDForum. Page generated in 0.69255 seconds
