[SOLVED]error while opening eclipse Luna [message #1436199] |
Thu, 02 October 2014 14:45 |
Xavier Flamant Messages: 8 Registered: February 2014 |
Junior Member |
I work with Eclipse Luna. When I try to open Eclipse I have the following error. It is chinese for me. Could you tell me what to do ? Thanks in advance. Here is the log file content
!SESSION 2014-10-02 16:29:52.482 -----------------------------------------------
eclipse.buildId=4.4.0.I20140606-1215
java.version=1.7.0_60
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=fr_FR
Framework arguments: -product org.eclipse.epp.package.jee.product -keyring /Users/xflamant/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.jee.product -keyring /Users/xflamant/.eclipse_keyring -showlocation
!ENTRY org.eclipse.jpt.dbws.eclipselink.ui 4 0 2014-10-02 16:30:01.457
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jpt.dbws.eclipselink.ui [394]
Bundle was not resolved because of a uses contraint violation.
org.osgi.service.resolver.ResolutionException: Uses constraint violation. Unable to resolve resource org.eclipse.jpt.dbws.eclipselink.ui [osgi.identity; osgi.identity="org.eclipse.jpt.dbws.eclipselink.ui"; type="osgi.bundle"; version:Version="1.1.100.v201310142259"; singleton:="true"] because it is exposed to package 'javax.xml.bind' from resources org.eclipse.osgi [osgi.identity; osgi.identity="org.eclipse.osgi"; type="osgi.bundle"; version:Version="3.10.0.v20140606-1445"; singleton:="true"] and javax.xml.bind [osgi.identity; osgi.identity="javax.xml.bind"; type="osgi.bundle"; version:Version="2.1.9.v201005080401"] via two dependency chains.
Chain 1:
require: (&(osgi.wiring.bundle=org.eclipse.wst.common.project.facet.ui)(&(bundle-version>=1.3.0)(!(bundle-version>=2.0.0))))
provide: osgi.wiring.bundle: org.eclipse.wst.common.project.facet.ui
Chain 2:
require: (&(osgi.wiring.bundle=org.eclipse.persistence.dbws.builder)(&(bundle-version>=2.3.0)(!(bundle-version>=3.0.0))))
provide: osgi.wiring.bundle; osgi.wiring.bundle="org.eclipse.persistence.dbws.builder"; bundle-version:Version="2.6.0.v20130815-a4708b6"
org.eclipse.persistence.dbws.builder [osgi.identity; osgi.identity="org.eclipse.persistence.dbws.builder"; type="osgi.bundle"; version:Version="2.6.0.v20130815-a4708b6"]
import: (osgi.wiring.package=javax.xml.bind)
export: osgi.wiring.package: javax.xml.bind
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.equinox.ds 2 0 2014-10-02 16:30:31.508
!MESSAGE [SCR - WorkThread] Timeout occurred! Thread was blocked on processing [QueuedJob] WorkPerformer: org.eclipse.equinox.internal.ds.SCRManager@e5c48f1; actionType 1
!ENTRY org.eclipse.equinox.ds 2 0 2014-10-02 16:30:31.543
!MESSAGE [SCR] Enabling components of bundle org.eclipse.ui.trace did not complete in 30000 ms
!ENTRY org.eclipse.core.runtime 4 0 2014-10-02 16:30:36.596
!STACK 0
org.osgi.framework.BundleException: Unable to acquire the state change lock for the module: osgi.identity; osgi.identity="org.eclipse.core.runtime"; type="osgi.bundle"; version:Version="3.10.0.v20140318-2214"; singleton:="true" [id=83] STARTED [STARTED]
at org.eclipse.osgi.container.Module.lockStateChange(Module.java:329)
at org.eclipse.osgi.container.Module.start(Module.java:389)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
!ENTRY org.eclipse.osgi 2 0 2014-10-02 16:30:44.380
!MESSAGE While loading class "org.eclipse.core.runtime.IExtensionRegistry", thread "Thread[Start Level: Equinox Container: a001df95-404a-0014-14ae-efd4aaf3f726,5,main]" timed out waiting (5000ms) for thread "Thread[Component Resolve Thread,5,main]" to finish starting bundle "org.eclipse.equinox.registry_3.5.400.v20140428-1507 [333]". To avoid deadlock, thread "Thread[Start Level: Equinox Container: a001df95-404a-0014-14ae-efd4aaf3f726,5,main]" is proceeding but "org.eclipse.core.runtime.IExtensionRegistry" may not be fully initialized.
!STACK 0
org.osgi.framework.BundleException: Unable to acquire the state change lock for the module: osgi.identity; osgi.identity="org.eclipse.equinox.registry"; type="osgi.bundle"; version:Version="3.5.400.v20140428-1507"; singleton:="true" [id=333] STARTED [STARTED]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:311)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.sources.MultiSourcePackage.loadClass(MultiSourcePackage.java:32)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:382)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:336)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:328)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:190)
at org.eclipse.equinox.internal.p2.repository.Activator.start(Activator.java:34)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319)
at org.eclipse.osgi.container.Module.doStart(Module.java:571)
at org.eclipse.osgi.container.Module.start(Module.java:439)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:370)
at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.watchDropins(Activator.java:539)
at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start(Activator.java:172)
!ENTRY org.eclipse.osgi 2 0 2014-10-02 16:30:50.277
!MESSAGE While loading class "org.eclipse.core.runtime.RegistryFactory", thread "Thread[Start Level: Equinox Container: a001df95-404a-0014-14ae-efd4aaf3f726,5,main]" timed out waiting (5001ms) for thread "Thread[Component Resolve Thread,5,main]" to finish starting bundle "org.eclipse.equinox.registry_3.5.400.v20140428-1507 [333]". To avoid deadlock, thread "Thread[Start Level: Equinox Container: a001df95-404a-0014-14ae-efd4aaf3f726,5,main]" is proceeding but "org.eclipse.core.runtime.RegistryFactory" may not be fully initialized.
!STACK 0
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.getAllSuffixes(AbstractRepositoryManager.java:427)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:659)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.initializeMetadataRepository(RepositoryListener.java:104)
at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.<init>(RepositoryListener.java:59)
at org.eclipse.equinox.internal.p2.reconciler.dropins.DropinsRepositoryListener.<init>(DropinsRepositoryListener.java:82)
[Updated on: Sat, 04 October 2014 07:28] Report message to a moderator
FUDForum. Page generated in 0.05104 seconds
