Home » Newcomers » Newcomers » [SOLVED]error while opening eclipse Luna
[SOLVED]error while opening eclipse Luna [message #1436199] Thu, 02 October 2014 14:45 Go to next message
Xavier Flamant is currently offline Xavier FlamantFriend
I work with Eclipse Luna. When I try to open Eclipse I have the following error. It is chinese for me. Could you tell me what to do ? Thanks in advance. Here is the log file content
!SESSION 2014-10-02 16:29:52.482 -----------------------------------------------
eclipse.buildId=4.4.0.I20140606-1215
java.version=1.7.0_60
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=fr_FR
Framework arguments:  -product org.eclipse.epp.package.jee.product -keyring /Users/xflamant/.eclipse_keyring -showlocation
Command-line arguments:  -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.jee.product -keyring /Users/xflamant/.eclipse_keyring -showlocation
!ENTRY org.eclipse.jpt.dbws.eclipselink.ui 4 0 2014-10-02 16:30:01.457
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jpt.dbws.eclipselink.ui [394]
  Bundle was not resolved because of a uses contraint violation.
  org.osgi.service.resolver.ResolutionException: Uses constraint violation. Unable to resolve resource org.eclipse.jpt.dbws.eclipselink.ui [osgi.identity; osgi.identity="org.eclipse.jpt.dbws.eclipselink.ui"; type="osgi.bundle"; version:Version="1.1.100.v201310142259"; singleton:="true"] because it is exposed to package 'javax.xml.bind' from resources org.eclipse.osgi [osgi.identity; osgi.identity="org.eclipse.osgi"; type="osgi.bundle"; version:Version="3.10.0.v20140606-1445"; singleton:="true"] and javax.xml.bind [osgi.identity; osgi.identity="javax.xml.bind"; type="osgi.bundle"; version:Version="2.1.9.v201005080401"] via two dependency chains.
Chain 1:
    require: (&(osgi.wiring.bundle=org.eclipse.wst.common.project.facet.ui)(&(bundle-version>=1.3.0)(!(bundle-version>=2.0.0))))
    provide: osgi.wiring.bundle: org.eclipse.wst.common.project.facet.ui
Chain 2:
    require: (&(osgi.wiring.bundle=org.eclipse.persistence.dbws.builder)(&(bundle-version>=2.3.0)(!(bundle-version>=3.0.0))))
    provide: osgi.wiring.bundle; osgi.wiring.bundle="org.eclipse.persistence.dbws.builder"; bundle-version:Version="2.6.0.v20130815-a4708b6"
  org.eclipse.persistence.dbws.builder [osgi.identity; osgi.identity="org.eclipse.persistence.dbws.builder"; type="osgi.bundle"; version:Version="2.6.0.v20130815-a4708b6"]
    import: (osgi.wiring.package=javax.xml.bind)
    export: osgi.wiring.package: javax.xml.bind
	at org.eclipse.osgi.container.Module.start(Module.java:434)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.equinox.ds 2 0 2014-10-02 16:30:31.508
!MESSAGE [SCR - WorkThread] Timeout occurred! Thread was blocked on processing [QueuedJob] WorkPerformer: org.eclipse.equinox.internal.ds.SCRManager@e5c48f1; actionType 1
!ENTRY org.eclipse.equinox.ds 2 0 2014-10-02 16:30:31.543
!MESSAGE [SCR] Enabling components of bundle org.eclipse.ui.trace did not complete in 30000 ms
!ENTRY org.eclipse.core.runtime 4 0 2014-10-02 16:30:36.596
!STACK 0
org.osgi.framework.BundleException: Unable to acquire the state change lock for the module: osgi.identity; osgi.identity="org.eclipse.core.runtime"; type="osgi.bundle"; version:Version="3.10.0.v20140318-2214"; singleton:="true" [id=83] STARTED [STARTED]
	at org.eclipse.osgi.container.Module.lockStateChange(Module.java:329)
	at org.eclipse.osgi.container.Module.start(Module.java:389)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
!ENTRY org.eclipse.osgi 2 0 2014-10-02 16:30:44.380
!MESSAGE While loading class "org.eclipse.core.runtime.IExtensionRegistry", thread "Thread[Start Level: Equinox Container: a001df95-404a-0014-14ae-efd4aaf3f726,5,main]" timed out waiting (5000ms) for thread "Thread[Component Resolve Thread,5,main]" to finish starting bundle "org.eclipse.equinox.registry_3.5.400.v20140428-1507 [333]". To avoid deadlock, thread "Thread[Start Level: Equinox Container: a001df95-404a-0014-14ae-efd4aaf3f726,5,main]" is proceeding but "org.eclipse.core.runtime.IExtensionRegistry" may not be fully initialized.
!STACK 0
org.osgi.framework.BundleException: Unable to acquire the state change lock for the module: osgi.identity; osgi.identity="org.eclipse.equinox.registry"; type="osgi.bundle"; version:Version="3.5.400.v20140428-1507"; singleton:="true" [id=333] STARTED [STARTED]
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)
	at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:311)
	at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
	at org.eclipse.osgi.internal.loader.sources.MultiSourcePackage.loadClass(MultiSourcePackage.java:32)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:382)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:336)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:328)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
	at java.lang.Class.forName0(Native Method)
	at java.lang.Class.forName(Class.java:190)
	at org.eclipse.equinox.internal.p2.repository.Activator.start(Activator.java:34)
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)
	at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936)
	at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319)
	at org.eclipse.osgi.container.Module.doStart(Module.java:571)
	at org.eclipse.osgi.container.Module.start(Module.java:439)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:370)
	at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.watchDropins(Activator.java:539)
	at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start(Activator.java:172)
!ENTRY org.eclipse.osgi 2 0 2014-10-02 16:30:50.277
!MESSAGE While loading class "org.eclipse.core.runtime.RegistryFactory", thread "Thread[Start Level: Equinox Container: a001df95-404a-0014-14ae-efd4aaf3f726,5,main]" timed out waiting (5001ms) for thread "Thread[Component Resolve Thread,5,main]" to finish starting bundle "org.eclipse.equinox.registry_3.5.400.v20140428-1507 [333]". To avoid deadlock, thread "Thread[Start Level: Equinox Container: a001df95-404a-0014-14ae-efd4aaf3f726,5,main]" is proceeding but "org.eclipse.core.runtime.RegistryFactory" may not be fully initialized.
!STACK 0
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.getAllSuffixes(AbstractRepositoryManager.java:427)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:659)
	at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
	at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
	at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.initializeMetadataRepository(RepositoryListener.java:104)
	at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.<init>(RepositoryListener.java:59)
	at org.eclipse.equinox.internal.p2.reconciler.dropins.DropinsRepositoryListener.<init>(DropinsRepositoryListener.java:82)
[Updated on: Sat, 04 October 2014 07:28]
Report message to a moderator
Re: error while opening eclipse Luna [message #1437333 is a reply to message #1436199] Sat, 04 October 2014 07:27 Go to previous messageGo to next message
I didn't solved the error, so I turned off my computer and start it again, then it worked without the error
Re: [SOLVED]error while opening eclipse Luna [message #1709703 is a reply to message #1436199] Wed, 30 September 2015 13:41 Go to previous messageGo to next message
John Conran is currently offline John ConranFriend
I took the first class reporting the error,
i.e. org.eclipse.osgi
and deleted the (lock) files under under configuration/org.eclipse.osgi/.manager
Files had names starting with .fileTable
I was then able to start Eclipse without a computer reboot but did have to specify the workspace when it restarted.
Re: [SOLVED]error while opening eclipse Luna [message #1711286 is a reply to message #1709703] Wed, 14 October 2015 14:57 Go to previous messageGo to next message
Carlos Ratzer is currently offline Carlos RatzerFriend
It worked perfect for me. Many Thanks!
Re: [SOLVED]error while opening eclipse [message #1728858 is a reply to message #1709703] Fri, 08 April 2016 04:26 Go to previous messageGo to next message
Nitin Jain is currently offline Nitin JainFriend
I had upgraded Eclipse Mars1 to Eclipse Mars2 but after update the process eclipse did not launch. Then I saw this post and follow the process and delete the mentioned .fileTableLock file. Problem is solved.
Thanks a lot !!!
Re: [SOLVED]error while opening eclipse Luna [message #1741417 is a reply to message #1709703] Wed, 24 August 2016 21:24 Go to previous messageGo to next message
Anirudh Reddy is currently offline Anirudh ReddyFriend
Thhanks for the solution.
Can you please explain me how are those files related to the problem? I had to delete not only .filetableLock but also .filetable.5 and .filetable.6
Re: [SOLVED]error while opening eclipse Luna [message #1749192 is a reply to message #1436199] Fri, 02 December 2016 21:45 Go to previous messageGo to next message
Prateek Agrawal is currently offline Prateek AgrawalFriend
Hello All,
I recently updated eclipse to eclipse-jee-neon-1a-win32. And it was working fine. One day, I received the following while at startup of eclipse:
!ENTRY org.eclipse.core.runtime 4 0 2016-12-03 02:49:54.224
!STACK 0
org.osgi.framework.BundleException: Unable to acquire the state change lock for the module: osgi.identity; type="osgi.bundle"; version:Version="3.12.0.v20160606-1342"; osgi.identity="org.eclipse.core.runtime"; singleton:="true" [id=113] STARTED [STARTED]
at org.eclipse.osgi.container.Module.lockStateChange(Module.java:337)
at org.eclipse.osgi.container.Module.start(Module.java:401)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
Caused by: java.util.concurrent.TimeoutException: Timeout after waiting 5 seconds to acquire the lock.
at org.eclipse.osgi.container.Module.lockStateChange(Module.java:334)
... 8 more
Root exception:
Thanks to the resposes mentioned in this page, I have deleted the files .fileTableLock, .fileTable7, .fileTable8 from the path {eclipse dir}\configuration\org.eclipse.osgi\.manager And it works fine now.
Re: [SOLVED]error while opening eclipse Luna [message #1763283 is a reply to message #1709703] Fri, 12 May 2017 10:57 Go to previous messageGo to next message
Shalin Shah is currently offline Shalin ShahFriend
What is the root cause of this issue?
As we are developing an eclipse RCP product and we are also facimg this issue when p2 update is performed.
And it solves the problem.by deleting .lock files.
How can we ensure that end user don't have to go through trouble and delete these files?
Re: [SOLVED]error while opening eclipse Luna [message #1766836 is a reply to message #1436199] Wed, 28 June 2017 01:54 Go to previous messageGo to next message
Meira Adlerstein is currently offline Meira AdlersteinFriend
To those who were helped by this solution-
"I took the first class reporting the error, i.e. org.eclipse.osgi and deleted the (lock) files under under configuration/org.eclipse.osgi/.manager. Files had names starting with .fileTable. I was then able to start Eclipse without a computer reboot but did have to specify the workspace when it restarted."
- see my screenshot (attached). When I open org.eclipse.osgi on my mac I don't see anything titled "manager", and not sure what is meant by deleting lock files. Can someone please help? Been trying to solve this for past 2 days. Thanks
Re: [SOLVED]error while opening eclipse Luna [message #1778975 is a reply to message #1436199] Wed, 27 December 2017 10:27 Go to previous messageGo to next message
Thorsten Gomann is currently offline Thorsten GomannFriend
...unsolved for me...
I have same error in log as mentioned above
So I deleted
configuration\org.eclipse.osgi\.manager\.fileTable.3
configuration\org.eclipse.osgi\.manager\.fileTable.2
configuration\org.eclipse.osgi\.manager\.fileTableLock
configuration\org.eclipse.osgi\framework.info.2
.metadata\.log
I also restarted, but nothing works for me.
I can create a new workspace, pull from git, work on it, save, restart, .... and one day I can't start eclipse on that workspace at all. Within the last three months it's my third workspace I can't open anymore...
What else can I do "just to open" my Eclipse again and continue working on my tiny project...?
Re: [SOLVED]error while opening eclipse Luna [message #1782735 is a reply to message #1749192] Wed, 28 February 2018 16:38 Go to previous messageGo to next message
Surya Shah is currently offline Surya ShahFriend
I tried with this and deleted files from "configuration\org.eclipse.osgi\.manager":
.fileTableLock
.fileTable.1
.fileTable.1
Then I start Eclipse and same files are created again, first .fileTableLock and followed by rest.
How to avoid this and launch Eclipse :(
PFA for the log file created in "eclipse\configuration": 1519835823181
Re: [SOLVED]error while opening eclipse Luna [message #1784427 is a reply to message #1709703] Tue, 27 March 2018 19:38 Go to previous messageGo to next message
Jaime Alberto Rodriguez is currently offline Jaime Alberto RodriguezFriend
Worked it for me, lots of thanks.
Re: [SOLVED]error while opening eclipse Luna [message #1807196 is a reply to message #1436199] Fri, 24 May 2019 13:36 Go to previous messageGo to next message
Saumya Saxena is currently offline Saumya SaxenaFriend
Thank you. deleting the TableLock file helped.
Re: [SOLVED]error while opening eclipse Luna [message #1815484 is a reply to message #1709703] Thu, 03 October 2019 10:49 Go to previous messageGo to next message
Sai Mantha is currently offline Sai ManthaFriend
It worked for me!!!
Thank you :)
Re: [SOLVED]error while opening eclipse Luna [message #1842480 is a reply to message #1815484] Mon, 21 June 2021 11:50 Go to previous message
Ilyas Ronef is currently offline Ilyas RonefFriend
2021-06.
Still works :)
Previous Topic:Eclipse 2021-06 macOS aarch64 builds, where are they?
Next Topic:Outline view collapses autoamtically
Current Time: Mon May 16 21:24:34 GMT 2022
Powered by FUDForum. Page generated in 0.03797 seconds
